where can you guys get flare wrenches from for your brake lines?
Old Dec 29, 2007 | 07:35 PM
Markb16a's Avatar
Default where can you guys get flare wrenches from for your brake lines?
Ok so I am doing a rear disc swap and so I cant get all the brakes lines off of the proportion valve with vise grips cant get int othe space in the engine bay and the intake mantifold and crap the thing is where can you get a flare wrench tool from sears maybe and if you guys use a flare wrench what size does it take for basic brake line fittings? thanks
95 civic cx btw
Old Dec 29, 2007 | 08:23 PM
cxSHOE's Avatar
Default Re: where can you guys get flare wrenches from for your brake lines? (Markb16a)
sears and should be 10mm
depending if your swapping out a m/c you may also need a 12mm
'97 itr rear calipers use an 11mm for future reference. your good with the 10mm
Old Dec 30, 2007 | 08:58 AM
Markb16a's Avatar
Default Re: where can you guys get flare wrenches from for your brake lines? (cxSHOE)
10mm is too small and 11 mm is too big so I dont know what to do
Old Dec 30, 2007 | 09:06 AM
Luserkid's Avatar
10mm is the correct size, make sure the nut is clean of dirt and rust and crap like that because the flare is a direct fit. Sometimes what i do is make sure its straight on and hit it down with another wrench. But 10mm is the correct size.
Old Dec 30, 2007 | 09:18 AM
Markb16a's Avatar
Default Re: where can you guys get flare wrenches from for your brake lines? (Luserkid)
well it stripps it out everytime and well it just doesnt work I *** up hard lines everytime I do this crap what do I do now have to take my motor out just to get the proportion valve off or just cut all the brake lines I cant get a vise grip in there. this is bullshit.
Old Dec 30, 2007 | 09:33 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a &raquo;</TD></TR><TR><TD CLASS="quote">well it stripps it out everytime and well it just doesnt work I *** up hard lines everytime I do this crap what do I do now have to take my motor out just to get the proportion valve off or just cut all the brake lines I cant get a vise grip in there. this is bullshit.</TD></TR></TABLE>
you should have posted prior to starting the project. 10mm is the right size for non abs hondas. they are a pain to get off, especially on the MC and the prop valve.
what i did was let them soak in wd-40 for a whole day (through out the day continuing the soak). this allowed some to break loose, for others i hit them up with a torch. this allowed the rust to free up allowing me to break them loose.
unfortunately, 2 lines where just not going to move. i ended up stripping them. so i cut and tried to re-flare them, but there was no success. i spent $140 on 2 new hardlines from Honda. the first was a breeze, it was the left front line. the other took me 7 hours, it was the right rear.
so be aware that you might have to resort to replacing the old lines with new ones.
Old Dec 30, 2007 | 10:39 AM
Markb16a's Avatar
Default Re: where can you guys get flare wrenches from for your brake lines? (philosofy1)
either this is what I am going to do
1 take off the intake mantifold today which is going to be a bitch because the 12mm nut under the intake mantifold in the middle is a bitch to get off and use some vise grips to take off the other lines
2 maybe try using wd-40 what you siad eariler but I am telling you the 10mm just like strips it out
3 I have no clue but take the damn motor out I really didnt know it was this freaking hard to change a damn proportion valve it would be so much easiler if it was like the da models there easy.
waldo1212
Dec 18, 2010 03:26 PM
ZCcivic91
Apr 27, 2009 01:50 PM
LilCivic04
Welding / Fabrication
37
Jun 22, 2007 10:06 AM
B96v6
Nov 10, 2005 09:16 AM
Big Teggie
Mar 27, 2004 05:28 AM
