2000 Accord Auto transmission slipping
Old Dec 29, 2007 | 01:15 PM
SL0WEGG's Avatar
Default 2000 Accord Auto transmission slipping
I'm trying to figure out whats wrong with it. I guessed it was the torque converter, but after reading several other threads i'm thinking it might be worse. The trans is slipping when you first start to move, it slips up to 2k and then kicks into first to move. Its been mentioned to me that it has slipping in higher gears, IE: 3rd going into 4th. I'm really trying to narrow it down to see if its even worth taking apart right now.Thanks in advance.
Old Dec 29, 2007 | 02:09 PM
hilltopgraphics's Avatar
Default Re: 2000 Accord Auto transmission slipping (boostedej1)
is this a V6 or L4?
How many miles?
Is it an OEM or Reman trans?
These answers will all be very helpful.
Old Dec 29, 2007 | 02:14 PM
361 accord's Avatar
Default Re: 2000 Accord Auto transmission slipping (hilltopgraphics)
you have to act kinda quick you have 7years+9months or 109Kmiles before ur expletiveed, if ur under that many miles/age u can get u a new one 4 FREE and ill give u the phone number you need to call,
Old Dec 29, 2007 | 11:24 PM
YeuEmMaiMai's Avatar
slipping is always clutch packs
slow accelleration = torque converter problems
Old Dec 30, 2007 | 10:38 AM
SL0WEGG's Avatar
Default Re: 2000 Accord Auto transmission slipping (YeuEmMaiMai)
Its an L4, way beyond the milage for the TSB. Its got like 200k+ Miles on it. I guess its the clutchpacks then because it accelerates normally except for the slight slippage.
Old Dec 30, 2007 | 11:13 AM
Mystral Hawk's Avatar
Try doing the tranny cooler and filter...might help. I know it helps some people and helps prolong the length of it a bit. Ive also heard of people asking for Honda Goodwill service if their tranny fails due to the same causes as the extended warranty suggest, with success. They'll like cover materials and you pay for labor or something.
But I suggest maybe doing a drain and fill, adding additional tranny filter and cooler, and see how it goes. I mean all in all its like 80$ worth of parts that can potentially save you a lot of grief.
Old May 16, 2008 | 07:55 PM
anoparticular's Avatar
New User
it might just be the shift solenoids going out...
Old May 16, 2008 | 08:02 PM
361 accord's Avatar
Default Re: 2000 Accord Auto transmission slipping (anoparticular)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anoparticular &raquo;</TD></TR><TR><TD CLASS="quote">it might just be the shift solenoids going out...</TD></TR></TABLE>
back from the dead
J Taylor
May 16, 2010 07:17 PM
AmericanPie
Transmission & Drivetrain
Jan 14, 2010 10:24 AM
fatman69
Apr 18, 2008 09:44 AM
shanevas2
Jan 3, 2005 04:32 PM
AznBoy1der
Sep 29, 2002 01:44 PM
