how much power can u make on a built D series?????
Old Dec 29, 2007 | 12:02 PM
Ramma's Avatar
Default how much power can u make on a built D series?????
i was just wondering how much power can i make on a built d series on pump gas
1 over bore cp 9,0 compression pistons scat rod arp rod bolts garret .63 exhaust side and i rev to 7800with a zex cam. y5 block and a z6 head with a darton sleeve kit. 65mm throttle body a victor x intake manifold, rc 750cc fuel injectors, hondata s200 arp head bolts 3'' down pipe, 2.5 inch side exit exhaust
Old Dec 29, 2007 | 06:35 PM
HiProfile's Avatar
Default Re: how much power can u make on a built D series????? (Ramma)
Well so far there's a 568whp D16 here, but I'm sure that's race gas. I can see you hitting 400+ if its all done correctly. I watched a built d16y8 (8.5:1) with 57trim, zex cam, 3" dp/exhaust, and 93 octane lay down 357whp at 18psi, with more left to go on both the turbo and gasoline. That was also with a y8 intake manifold and stock sleeves.
With yours being 9:1, you might be a limited to a slightly lower boost level, but should make a few more HP per psi. Assuming you upgrade your stock fuel pump, you could probably near 400whp, if not push past it.
Old Dec 29, 2007 | 08:34 PM
mike93eh2's Avatar
i wouldnt go past 350 on pump gas..
MikeySpec
Sep 27, 2013 09:20 PM
datsun71
Aug 1, 2012 08:13 AM
Humble Performance
43
Mar 12, 2010 08:24 PM
spunautosports
17
Nov 14, 2006 08:52 AM
BoOsTiN Dc2
Mar 11, 2004 06:11 AM
