B20Vtec stock sleve Usage and Mileage
Old Dec 28, 2007 | 06:39 PM
pasaunde's Avatar
Default Stock Sleve B20Vtec Longevity ???
I started this thread in an attempt to catalog stock sleve b20 builds, mileage, mods, usage and
estimated mode of failure if and when it happens. HT has several dyno threads but not a cradle to grave accounting of these builds in one place. Anyone who has one or even old setups would be useful if you can remember the details. I will be updating my information good or bad every few weeks, hope everyone will do the same.
There are alot of different opinions about the reliability of this setup and I would like this to eventually be used as a resource for others considering a stock sleve B20 build.
Dyno https://honda-tech.com/zero...ge=20
Here is a similar thread that stopped https://honda-tech.com/zerothread?id=1647464
B20 85mm stock sleves
B20 crank
Block guard
GSR girdle
ITR Cams
B16 head
260 psi All cylinders
TriY header
Sheet Metal IM
210hp 148Tq (ITR Cams) / 225 hp 156Tq (Pro2s)
ECU Crome
Fuel Cut 8k
~34 MPG Highway (With ITR Cams) / 30 MPG Highway (Pro2s)
Starting Mileage 230,452
Now..12-15-11....260,285
Total....................29,833
Daily Driven 27,499 miles
Road Course 2,334 miles @ (5000-8200 rpms)
2.5" Exhaust, Flow Master 40 Series Delta Flow -Two Chamber Mufflers / No Cat
3" Exhaust 2x Summit glass packs / No cat
http://video.google.com/videoplay?do...58561393&hl=en
ITR Cam Dyno
My Favorite
http://www.youtube.com/watch?feature...v=47H876-_sJA#
The Ride
Old Jan 1, 2008 | 12:04 PM
badboyr66's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage (pasaunde)
Good thread idea.... smoking a doobie in your honor
subscribed
Old Jan 3, 2008 | 06:29 PM
pasaunde's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage (badboyr66)
Thanks for the props, I built it, tuned it and will eventually destroy it. Half of everything I've learned "insert joke here", has been from others willing to share. Hope this helps someone.
Modified by pasaunde at 10:05 AM 1/10/2008
Old Jan 3, 2008 | 07:15 PM
mouab18c1's Avatar
Awesome idea...post mine when its running right
Old Jan 3, 2008 | 08:46 PM
ProMotive's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage (mouab18c1)
Great idea for a thread subscribed
Old Jan 13, 2008 | 08:41 PM
badboyr66's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage (ProMotiveConcepts)
bumping for others to see.
Anyone have any updates.... too much snow here
Old Feb 21, 2008 | 01:40 PM
pasaunde's Avatar
Just got back from another HPDE event (NASA @ CMP), put another 100+ miles on track with this setup and everything is still going strong. I'll be going to the We-Todd 3 in April. If anyone lives near CMP it's a great way to spend a weekend and get on track the Honda/Acura crowd.
WEE-TODD 3
https://honda-tech.com/zerothread/2180506
Old May 10, 2008 | 06:08 PM
badboyr66's Avatar
Default Re: (pasaunde)
updates anyone?
Old May 10, 2008 | 08:40 PM
Slothy's Avatar
Default Re: (badboyr66)
B20 84.5 RS Machine's ITR spec pistons (stock sleves)
B20 crank
Stock B20 rods w/ ARP rod bolts
Stock main caps & bolts
Standard ACL bearings
B16 head
Stock valves
CTR cams and springs
AEBS intake mani, 68mm TB
370cc RC Engineering injectors
4-2-1 header, 2 1/4" exhaust, baffled muffler
Crome, fuel cut @ 8300
Motor now has a little over 3000kms on it (just under 2000mi). Haven't dyno'd yet, still running a street tune, but it should be in the 190-200whp/ 130-140ft lbs range. I'll update this when it gets on a dyno.
Old May 10, 2008 | 09:11 PM
badboyr66's Avatar
Default Re: (Slothy)
Sweet. Hope the dyno session is good to you and keep us updated
Old May 12, 2008 | 04:00 AM
pasaunde's Avatar
Slothy, Get a 2.5" exhaust and tune ASAP, let that 2.0L breathe !
I went to another track day but haven't put up the numbers yet. I've been spending most of my free time working on the 24 hrs of Lemons car for the July South Event
https://honda-tech.com/zerothread?id=2198816
I'll be going to ITR Expo 08 in June, that's VIR full course
Old May 12, 2008 | 04:31 AM
alphaq69's Avatar
stock b20b block stock b16 head
ctr cams, i, 2' exhaust, untuned 173whp.
13.5@ 101 2.0 60ft.
i put about 15000km before the tfitting i had used for my oil pressure gauge broke.... oil starvation.. blah blah blah.. sob story lol
Old May 12, 2008 | 06:05 AM
pasaunde's Avatar
Default Re: (alphaq69)
Sorry for your loss, a moment of silence........................................... ......................
So, 9320 miles for all you standard unit folks
What was you usage and fuel cut??
Old May 12, 2008 | 08:56 AM
be18see1's Avatar
im building one on 84mm stock sleeves this summer, will report back!
Old May 12, 2008 | 11:32 AM
.Manny.'s Avatar
Touching My Member
Default Re: (be18see1)
I'm building the following as a daily:
84.5mm Stock Sleeves.
RS Machine ITR pistons.
ITR 87mm Stroke Crank.
GSR/ITR Eagle H-Beam rods.
Stock Port B16 head.
Crower Valvetrain.
S2S2 Cams.
Edelbrock Performer X Manifold.
Power Ent. 68mm TB.
JG Edelbrock header.
I'll let you know how it holds up in the coming months.
Old May 14, 2008 | 05:49 PM
DOHCter's Avatar
Default Re: (.Manny.)
I'm in on this one
My setup:
B20Z stock bore, stock sleeves
RS ITR dome pistons 84mm
ITR head, stock ports
JDM Concepts full valvetrain
JDM Concepts high lift cams
RC 440cc injectors
Big Tube stepped header
Omni 2.5 in test pipe
Apexi WS2 exhaust
Kordenbrock Motorsports oil catch can breather kit
Password CF intake tube
LS tranny for those freeway and city driving (need my ITR back)
Action DD/ Kevlar clutch
Made 205hp/14x tq w/ exhaust - 209/148tq unbolted exhaust at B-pipe
Tuned at JDM Concepts with my Apexi Power FC and Commander- 8400rev
Been Dailying this for quite some time now (approx 1yr 3months) just fine.
Recently had my intake cam snap in half while at approx 7500rpms. Got a little lucky because no major damage done to motor and was driving again the next day on stock GSR cams and stock JDM ITR ECU and JDM ITR injectors. Although I need new rockers (pads got worn down some) and 2 valves (leakdown is at about 5% in one cylinder)
So now i'm DD with just cruising around under 4500 rpms so as to not burn the valve until i get the new rockers and valves.
Old May 14, 2008 | 06:28 PM
b20vtech's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage 5/08 (pasaunde)
i know the word mileage is involve in the title of this thread, so im gonna ask u guys " what MPG are u guys getting on ur stock internal or built b20 vtec's?
Old May 14, 2008 | 06:42 PM
pasaunde's Avatar
I get about ~ 33 mpg Highway that's running
a JDM FD (4.875) and an LS fith gear. Ontrack it's more like 15 mpg.
Old May 14, 2008 | 07:15 PM
badboyr66's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage 5/08 (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">i know the word mileage is involve in the title of this thread, so im gonna ask u guys " what MPG are u guys getting on ur stock internal or built b20 vtec's?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=2277671
Old May 15, 2008 | 05:10 PM
DOHCter's Avatar
Default Re: B20Vtec stock sleve Usage and Mileage 5/08 (badboyr66)
my last tank i got 32 mpg on the average driving to and from work.. have an LS tranny on my B20V.
Old May 16, 2008 | 11:22 AM
Slothy's Avatar
I get 22mpg 100% city driving w/ b16 tranny.
(400kms/ 43L of fuel - 250mi/ 11.36gallons)
Old May 16, 2008 | 06:57 PM
LERRY's Avatar
B20B 84.5mm stock sleeves
Golden Eagle block guard
Mild ported ITR head
s2s2 cams
Custom 52mm ITBs
JG Edelbrock Race Competition header
3" piping
CP 11.5 c/r pistons
Eagle H-Beams
I made 220whp with ITBs, 210whp w/ Skunk2 Pro series manifold and 70mm TB. I put about 5000 miles on it before I sold it. It's seen 10k rpm a few times.
Dyno Vid:
My B20 vs K20:
Modified by LERRY at 10:30 PM 5/16/2008
Old May 17, 2008 | 03:45 AM
pasaunde's Avatar
Nice fo-doh !!!
Guys don't forget to include Fuel Cut, and Usage: DD, Drag, Road Race or a combination. Later
Old May 17, 2008 | 04:04 AM
7601chexplicit's Avatar
Default Re: B20Vtec Stock Sleve Usage and Mileage 5/08 (pasaunde)
2000 civic si
rs machine 84mm pistons
eagle rods
Ls micropolished crank
stock 00 b16 head
stock cams
arp head studs
aebs intake manifold
68mm tb
dc headers
aem intake
9lbs exedy flywheel
chipped p06 running vtec
stock injectors and fuel pump
shifting at 8200.... 2000 miles so far, waiting on my cams to get here to get dyno tuned.
had to settle for obx stage 1, wanted Blox B's, but they were sold out and im very impatient. hoping for at least 200whp.
what do you guys think?
Old May 17, 2008 | 11:34 AM
eg714's Avatar
Default Re: B20Vtec Stock Sleve Usage and Mileage 5/08 (7601chexplicit)
good thread how many of you true street car guys do long distance trip (say 500 miles each way) driving with your stock sleeve b20vtec build? reason i ask is im going to be done with my 1st time b20vtec build soon and i travel alot from so cal to nor cal like once every other month
