oil spraying from valve cover vent tube? ideas why? boost caused?
i have a turbocharged dohc zc. it has been boosted for about 6 months now with no problems but just recently alot of oil and smoke has been coming from the valve cover vent tube. it has never done it before so i have always left it open, and now everytime i boost tons of oil sprays out. i thought it migh be cause my headgasket was leaking a little so i changed the headgasket and still under boost it sprays. any ideas? it has never done it before in the 6 months its been turbocharged. what could be the cause. thanks in advance.
oil hasnt came from there the entire time its been boosted, and its an exessive amount enough to shoot over the IM bounce off the firewall onto the underside of my hood and out the front of the hood. Excessive amounts. i have thought about a catch can but again oil never came out.
could i check the possibility of weak rings with a compression test? could a bad pcv valve cause the oil to spray like that possibly?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">oil always comes out of there
hook it up to a catch can</TD></TR></TABLE> did u read his Q? if you are now getting more oil out of vc then before and getting smoke out of the vc sounds like your rings are getting weak, you should check the pcv valve to make sure it's not stuck, but i it sounds like rings. try one comp test dry then try one putting about 1/2 oz oil in the cylinder and see how the results change.
okay thanks i will try that, i just replaced the pcv valve so hopefully that will help.
I toasted many turboed DOHC ZC
., damn shhty tuning w/ cast pistons......did any of the bores look like this??NOT good
no thank goodness. what setup were you running? shhhty tuning hu, im running a blox fmu now thats shhhty, for some reason i cant get my moates burn2 to work so i have to use the fmu until i can, its worked so far...
sounds like fried rings, possible ringland problem, but my cash is on rings/cylinder walls.
If you get a sudden excess of pressure from the block, it means it's escaping the cylinders, and is trying to go out of the block.
Whatda2
Nov 2, 2009 08:42 AM
inline976
May 4, 2005 02:54 AM
Lude_Behavior_97
Jan 19, 2005 07:20 PM
superR303
Apr 23, 2002 05:06 AM
