Removing forged pistons and installing a new set of same type. Should it drop right in without modif
Old Dec 28, 2007 | 09:42 AM
jetlude's Avatar
Default Removing forged pistons and installing a new set of same type. Should it drop right in without modif
Replacing slightly damaged je's(lean condition) with new ones of the exact same type. Generally, should they be a direct replacement without machining block
Old Dec 28, 2007 | 11:03 AM
BLKTeg94's Avatar
Slightly damaged?? Your gonna want to hone the block man.
Old Dec 28, 2007 | 11:39 AM
93supercoupe's Avatar
Default Re: (BLKTeg94)
im gonna say that the most correct way is to have the block honed
But if ur trying to do it quick/cheap, i think it would be fine aslong as u use the old rings, reason being, that they are already seated to that hone.
I dont think thats the right way to do it, but thats upto u.
Old Dec 29, 2007 | 08:03 PM
slowcar's Avatar
Default Re: (93supercoupe)
pull them out, check for grooves/scuffs, hone, new pistons, new rings. do it right and you will only have to do it once.
Old Dec 29, 2007 | 08:06 PM
boosstboy's Avatar
Default Re: (slowcar)
if your pistons are messed up, then more then likely so is the block.
91ls-v
May 25, 2005 08:03 AM
NoVALude
May 13, 2005 02:06 AM
Aaron.Hillman
Mar 1, 2004 10:27 AM
Robban26
15
Jan 24, 2004 01:31 AM
KC GSR
Jun 20, 2002 08:47 AM
