how to change driver side b series axles on eg civic
Old Dec 28, 2007 | 08:29 AM
Powered by VTEC's Avatar
Default how to change driver side b series axles on eg civic
i think the driver side b series axle might have gone bad and i am thinking of replacing it this weekend.i have all the tools and the parts ready.i am just wondering what are the step by step procedures to do the driver side axles swap . i basically know how to do it but just need to comfirm again.thanks
it should be easier than passenger side cause i dont have to drain the tranny fluid and it is only connected to half shaft axle. please advise.thanks guys
Old Dec 28, 2007 | 08:57 AM
B16B_coupe's Avatar
HRD PKR
Default Re: how to change driver side b series axles on eg civic (Powered by VTEC)
remove the lug nuts, step one
remove the wheel, step 2
remove lower ball joint bolt step 4
bust lower ball joint loose and remove from lower control arm step 5
remove the lower fork off the shock, step 6
remove axle step 7
Old Dec 28, 2007 | 09:01 AM
Default Re: how to change driver side b series axles on eg civic (B16B_coupe)
all right thanks man.
jadugartir's Avatar
Take off wheel. Disconnect lower ball joint, strut fork. take off axle nut. spray on some wd40 then swing the hub out of the way, axle should slide out of the hub. Now pull the axle out of the transmission.
Once its out, pop in the new one, i usually give it a little tap to make sure the retaining clip goes in all the way. Then put all your bolts back. If everything goes smoothly it should only take about 30 minutes. If you have a rust bucket maybe longer.
Old Dec 28, 2007 | 09:23 AM
SkoundrelUSA's Avatar
cute little bastard
"I have detailed files..."
https://honda-tech.com/zerothread?id=382416
Obviously only follow the axle instructions
Old Dec 28, 2007 | 10:12 AM
crazyguy's Avatar
Default Re: how to change driver side b series axles on eg civic (SkoundrelUSA)
good write up.good link
sanman000719
Jul 7, 2011 07:47 PM
ugandaHonda97
Dec 15, 2010 12:59 PM
sony224422
Jul 7, 2007 03:29 PM
kefka
Jul 16, 2004 03:34 PM
Passaudi1.8t
Jan 13, 2004 10:01 PM
