Problem #2
Old Jun 28, 2002 | 01:16 PM
.Beaver's Avatar
Bloody Beaver
Default Problem #2
Well I replaced the saprk plug tube gaskets, the valve cover gasket, (refer to Leaky Valve Cover) and all that went smoothly. But after I got everything put back together, and took it out for a drive, and after about 10miles or so, it started shaking, and vibrating below 2000 rpm, in any gear. A friend told me its the struts, and that his 240sx, and RX7 do the same.....so help me out again. Thanks
Old Jun 28, 2002 | 01:19 PM
Spade's Avatar
Default Re: Problem #2 (1 Evil Civic)
At any traveling speed it vibrates or the engine vibrates below 2000?
Old Jun 28, 2002 | 04:51 PM
hatchdrvr's Avatar
Struts don't do that that I've ever experienced. I'm not sure what it could be, but I'm almost possitive it's not the struts. Good luck with it.
Old Jun 28, 2002 | 06:04 PM
Honda4CX-T's Avatar
Have you skecked your Exhaust manifold gasket yet ? Try that I've this type of problem before.
Old Jun 29, 2002 | 05:28 AM
94CivicSi's Avatar
Default Re: Problem #2 (Honda4CX-R)
sounds to me like it's running on 3 cylinders. Check to make sure one of your spark plug boots didn't pop off.
Blown shocks will not cause the car to vibrate or shake.
Old Jun 29, 2002 | 07:48 AM
MikeMAN's Avatar
Default Re: Problem #2 (94CivicSi)
i have had that problem too, take all the spark plug wires off and press them down again as hard as you can...
are you getting a check engine light??
thanks,
mike
Old Jun 29, 2002 | 05:57 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Problem #2 (MikeMAN)
92+ civics don't have struts anyways, they're shocks, not the old school McPherson strut setup with torsion bars anymore...
Old Jun 29, 2002 | 07:10 PM
97hb's Avatar
Yeah sounds like three cyl. It would also idle very poorly with 3 cyl.
Old Jun 29, 2002 | 07:18 PM
POLLO's Avatar
Well, I know everyone has done this before so check it out...
Make sure that each wire is connected to the proper spark plug to its correspondent cylinder.
Jesse M
Honda Civic (2001 - 2005)
Sep 13, 2018 01:42 PM
Just me
Dec 20, 2008 04:16 PM
krytykalintentions
May 4, 2007 05:41 AM
civicxspower
Jun 5, 2005 04:12 PM
94teg_RS
Sep 13, 2004 11:27 PM
