F/S F/T JDM F22B built w/ turbo w/ ecu w/ transmisson w/ exhaust
Everything you need to get that car mobile with some power.
Great swap for a 90-97 accord!!!!!! Or a civic hatch, integra. What ever you want to put it in.
JDM F22B block-
Darton Mid Sleeves
Crower I-beam billet rods
ACL Bearings
Wiseco 9:2.1 pistons and rings
Block was decked
Head-
All stock internals
550 RC injectors
GM 3bar MAP Sensor
H22 62mm Throttle Body - port matched.
All new gaskets and seals and bearings
Block has around 7k miles on it, and the head has about 5k miles with new seals and around 60-70k on internals.
Transmission-
97 accord
Only has 22k miles - was taken apart and inspected before installation. Was just installed a week ago.
ACT heavy duty pressure plate w/ 6 puck racing disk
8.8lbs Fidenza flywheel.
Turbo-
Turbonetics T3/T4 .57trim- turbo with 7k miles and been well taken care off.
HKS BOV
Tial Wastegate 38mm w/ 9 psi spring
28x8x2.5 FMIC
Charge piping for a 94-97 Honda Accord
F22 log manifold
2.5 inch dowpipe
Also included is a 2.5 inch test pipe w/ 2.5inch Apexi N1 catback exhaust.
ECU-
P28 socketed ECU street tuned on Crome @ 7psi.(Tuning done by Matt Shue) I also have a S100 chip that was tuned on 14psi that was not a great tune. The S100 chip needs to be retuned.
This motor does not burn nor leak any fluid. It gets its oil changed about every 1500-1700 miles. The motor has no knocking nor any noises. Runs great, pulls strong.
The motor is still in the car so a test ride is very possible for serious inquiries.
Price is 6k OBO
Accepting trades also.
JDM F22B block-
Darton Mid Sleeves
ACL Bearings
Block was decked
Head-
All stock internals
550 RC injectors
GM 3bar MAP Sensor
Transmission-
97 accord
Turbo-
HKS BOV
28x8x2.5 FMIC
F22 log manifold
2.5 inch dowpipe
ECU-
Price is 6k OBO
fastazzf22
Jun 22, 2009 08:56 PM
