vtec issues
Old Dec 27, 2007 | 01:21 PM
92hatchboi's Avatar
Default vtec issues
The problem that I'm havin is when vtec engages the car loses power and when it reaches 6000rpm then it takes off. Vtec is set at 5000rpm. Could it be a bad chip cause the ecu is chipped
Old Dec 27, 2007 | 01:25 PM
Syndacate's Avatar
How did you arrive at 5000 RPM? Did you pull the number out of your *** or is that where it's making optimal horsepower in accordance with a dynometer?
More info would also be nice, year engine, engine model, upgrades, etc.
Old Dec 27, 2007 | 01:27 PM
groundzerocivic's Avatar
Default Re: vtec issues (92hatchboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">The problem that I'm havin is when vtec engages the car loses power and when it reaches 6000rpm then it takes off. Vtec is set at 5000rpm. Could it be a bad chip cause the ecu is chipped</TD></TR></TABLE>
Old Dec 27, 2007 | 01:38 PM
92hatchboi's Avatar
Default Re: (Syndacate)
Its an lsvtec with 11.5 to 1 compression. The vtec was set at 5000rpm when the ecu was chipped. Its in a 92 cx hatch
Old Dec 27, 2007 | 02:03 PM
92hatchboi's Avatar
Default Re: (92hatchboi)
Anybody????
Old Dec 27, 2007 | 02:15 PM
b16b_eg3's Avatar
Do you have stock cams? What's your redline? You might wanna UP the fuel pressure to compliment the early vtec or have the vtec set higher up the rpm. Your cams might not be making enough power.
Old Dec 28, 2007 | 08:36 AM
92hatchboi's Avatar
Default Re: vtec issues (b16b_eg3)
i have skunk2 stage 2 cams. skunk2 intake manifold. jg headers, 2.5" custom exhaust, ive tried changing the vtec engagement points with my vafc and it does the same thing until the car reaches 6000rpm then it starts pulling hard
Old Dec 28, 2007 | 08:43 AM
sohctodohc's Avatar
sounds like you need a complete tune, not just a chip or you "messing" with your vafc.
DarikDisease
Aug 26, 2008 01:29 PM
VTECth1s
Aug 22, 2006 09:53 AM
ROOROWNS
May 9, 2005 08:49 AM
VTC_CiViC
Dec 26, 2003 09:41 AM
