question about clutch (need answers)
Old Dec 26, 2007 | 08:09 PM
ja20_eg's Avatar
Default question about clutch (need answers)
i put a new clutch in and i bleed the clutch but the pressure on clutch is soft... is it suppose to be like that? i bleed it a couple of times but still the same.... is there something that i didn't do right?
Old Dec 26, 2007 | 08:11 PM
ek-g6's Avatar
Default Re: question about clutch (ja20_eg)
how did you do it..take us through your steps in bleeding a clutch..it could be that your clutch is new?
db8db8db8's Avatar
do you have an OEM clutch or aftermarket?
Old Dec 26, 2007 | 08:13 PM
db8db8db8's Avatar
Default Re: question about clutch (db8db8db8)
how does it drive? or does it?
Old Dec 26, 2007 | 08:16 PM
ja20_eg's Avatar
its a stock clutch... will i open up the bleed,step on the clutch 3 time just to pump out air. then close it back up. then pump the clutch.. that what i did to my other swap n it work find.... so dont no whys that...
Old Dec 26, 2007 | 08:17 PM
ja20_eg's Avatar
it drive fine but i seem to soft....???
Old Dec 26, 2007 | 08:21 PM
ek-g6's Avatar
did you do it by yourself or did you have someone step on the clutch, then after being stepped on for a couple times, did they or you hold it down there?
Old Dec 26, 2007 | 08:25 PM
ja20_eg's Avatar
Default Re: question about clutch (ek-g6)
well on my other swap i did it by my self. but on this one my bro help me on it .....but is that what im sopose to do on bleedding a clutch....
Old Dec 26, 2007 | 08:29 PM
ek-g6's Avatar
They way i did is..
friend open up bleeder nut
i pump 5 times, then stepped on it all the way
friend quickly close bleeder nut
brought clutch pedal back up and returned to how it was...
Old Dec 26, 2007 | 08:35 PM
ja20_eg's Avatar
so....pretty much on the 5th pump one person has to close the bleeder nut b4 i bring clutch pedal back up right ...
Old Dec 26, 2007 | 08:37 PM
ja20_eg's Avatar
if thats right then i tried doing that 2morrow n c if it work.....so if it still the same would u know whys that like that.....
Old Dec 26, 2007 | 08:39 PM
Vtec Civic 93's Avatar
Right, on the 5th pump hold it down, while its held down have your friend quickly close the bleeder screw, then u can let your foot off.
Old Dec 26, 2007 | 08:42 PM
ek-g6's Avatar
Default Re: question about clutch (Vtec Civic 93)
yep, and it should go back to being somewhat hard, or to your liking hope it helps you good luck
ja20_eg's Avatar
k but what if its still the same how it is right now.....
Old Dec 26, 2007 | 08:48 PM
ek-g6's Avatar
i would say its just how the clutch kit was made, some are hard and some are soft, that would be my explanation.
Old Dec 26, 2007 | 08:55 PM
ja20_eg's Avatar
k man thank for the info
Old Dec 26, 2007 | 09:00 PM
ek-g6's Avatar
aslong as your clutch engages all is good, make sure you fluid levels are up, years ago when i didnt know anything about honda, i didnt have a brake fluid in the clutch resovior, and my clutch didnt want to grab as much, it made a supercharger noise, and annoyed the hell out of me..didnt know what it was untill my friends bro in law just bled the clutch and all was good..for a day people thought i really did have a supercharger, and wanted to race, but i knew i would lose, cuz i couldnt go faster than 30 without hearing the noise. I had something that sounded like a supercharger, but definitely didnt make my car go faster..lols best of luck to you tho.
Old Dec 26, 2007 | 09:08 PM
ja20_eg's Avatar
lol ya thanks
esca
Oct 1, 2004 10:27 AM
CBRF4i
Honda Motorcycles
Jun 16, 2004 07:00 AM
MachAF
Mar 17, 2003 10:24 AM
MachAF
Mar 14, 2003 03:46 PM
