LS VTEC PROBLEM! Help all you honda techs-
Old Dec 26, 2007 | 05:36 PM
HONDABOND0255's Avatar
Default LS VTEC PROBLEM! Help all you honda techs-
I just finished my ls vtec swap, fully built n/a b18a bottom end, b16a2 head. P28 chipped to a p30. Had it towed to get tuned, and they couldn't get vtec to work. All sensors are connected, knock-vps, and vs. I have 12v at the vtec solenoid when vtec rpm is reached but engine doesn't switch to highcam. Oil pressure is 55 psi at the head. what am i missing? need some honda tech help.
Old Dec 26, 2007 | 05:39 PM
z6hatchboy's Avatar
Is the solenoid good, and is the correct setting marked in the tuning program, and how about the coolant temp sensor?
Old Dec 26, 2007 | 05:43 PM
Default Re: (z6hatchboy)
if the coolant temp sensor was bad, would i still see 12v at the solenoid- i also ran 12 v directly to the solenoid and it clicks- the ecu is chipped but still not tuned- the tuning guys put a vtec window from 4600 -7900
Old Dec 26, 2007 | 05:46 PM
z6hatchboy's Avatar
a certain coolant temp is needed for vtec to work also, but if its clicking that means its workings doesnt it? Problem may lay in the internals of the head.
Old Dec 26, 2007 | 05:47 PM
saleensolution's Avatar
Default Re: (HONDABOND0255)
how are you measuring pressure at the head? and what size line are you running? where are you tapping into the the head at? i had a problem like this once and pressure was not getting to the to keep vtec engaged
Old Dec 26, 2007 | 05:48 PM
do you know which coolant temp sensor? after all the wiring is tripple checked- i have no other choice but to start pulling the head apart-
Old Dec 26, 2007 | 05:51 PM
z6hatchboy's Avatar
I thought there was only one, on the side of the head, but if the sol. clicking i doubt thats the problem, and therefore think its inside the head.
Old Dec 26, 2007 | 05:52 PM
Default Re: (saleensolution)
i tapped the head on the passenger side rear of the head, the line goes straight to the T fitting which shares the same port as the oil pressure sensor. I believe the line is 3/8- i'm measuring the pressure at the pressure line going into the head with a pressure guage- what size line should i use? and what did you do to correct this because its driving me nuts-
Old Dec 26, 2007 | 05:54 PM
crawlin's Avatar
just brain storming here. did you do all the ls/vtec stuff? plug the head? tap the head? did you tap the head on the pss backside top right by the dist?
stupid question maybe low on oil?
just trying to throw stuff out there
Old Dec 26, 2007 | 05:56 PM
the bigger the line the more pressure your gonna need? what oil pump are you using? i ran a vtec oil pump and ran a -4 line. with a smaller line the less volume you will need to keep the head suplied with oil
Old Dec 26, 2007 | 05:59 PM
i built the engine, i'm familiar with alot of swaps but this ls vtec is my first. the car has plenty of oil, so your saying use a smaller line to increase oil pressure?
Old Dec 26, 2007 | 06:03 PM
yes, there is a difference between pressure and volume
Old Dec 26, 2007 | 06:17 PM
kinda like if you stick your thumb over a water hose, what happens? the pressure of the water increases
T3k C
Mar 19, 2007 02:22 PM
markhonda
Dec 13, 2006 08:13 PM
Demented
May 29, 2005 11:08 PM
theEGkid
Apr 20, 2005 07:56 AM
