New Guy Problems with the VAFC on 99 si
Old Dec 26, 2007 | 03:26 PM
pushin_hondas99's Avatar
Default New Guy Problems with the VAFC on 99 si
i hooked up my vafc and the car was missing really bad and the check engine light was on and flashing any advice???
Old Dec 26, 2007 | 03:27 PM
Padawan's Avatar
Darth ModerVader
Default Re: New Guy Problems with the VAFC on 99 si (pushin_hondas99)
You either hooked it up incorrectly or set it incorrectly.
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: New Guy Problems with the VAFC on 99 si (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You either hooked it up incorrectly or set it incorrectly. </TD></TR></TABLE>
Read the instructions. make sure it's set on 4 cylinder mode and has a sensor # of 6
Old Dec 26, 2007 | 03:29 PM
will it do that if im missing an o2 sensor
Old Dec 26, 2007 | 03:30 PM
Padawan's Avatar
Darth ModerVader
It won't run very well if your primary O2 is missing. The secondary O2 will not cause any issues other than a CEL.
Old Dec 26, 2007 | 03:35 PM
alright thanks guys and its the 02 sensor towards the back of the car
Old Dec 26, 2007 | 03:38 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushin_hondas99 &raquo;</TD></TR><TR><TD CLASS="quote">its the 02 sensor towards the back of the car</TD></TR></TABLE>
That isn't causing your problem.
Old Dec 26, 2007 | 03:45 PM
z6hatchboy's Avatar
Did you do the initial setup, it says wit a caution beside it, turn key over (dont turn car on) and go through the initial setup. And make sure you have tps (dont kow if it has a map voltage) set correctly voltage wise, there is a choice of declining and rising voltage. (which is when you press the gas, voltage goes up or down, that may be your problem)
Old Dec 26, 2007 | 03:57 PM
Default Re: (z6hatchboy)
i noticed that the voltage goes down when i hit the gas
Old Dec 26, 2007 | 04:04 PM
Default Re: (pushin_hondas99)
also i dont know too much about it i bought it with no directions or anything just the vafc so i dont know how to do the setup stuff
Old Dec 26, 2007 | 04:19 PM
B serious's Avatar
go to the apexi website. http://www.apexiusa.com, I think. You can download the instructions for free.
Old Dec 26, 2007 | 04:40 PM
z6hatchboy's Avatar
Default Re: (B serious)
, hope you have high speed
Adamd
Jul 24, 2008 02:48 AM
Casual Gcode1
Nov 14, 2006 09:33 PM
kHoA DoGG
Oct 25, 2002 09:20 AM
Unjockable
Aug 3, 2002 05:27 PM
senpai
Apr 22, 2002 06:31 AM
