air filter
i just bought an aem sri pipe came with no filter. should i just a k&n cone filter or something else like aem dryflow filter, injen filter, etc. does those filters that have built in velocity stack make a difference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy »</TD></TR><TR><TD CLASS="quote">k&n
</TD></TR></TABLE> ftw
To answer your Q's yes you can use any of the filters you stated just as long as the diameter is the same on both the tube and filter. As for those velocity stacks I would assume that they would give more power... but its just an intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T »</TD></TR><TR><TD CLASS="quote">To answer your Q's yes you can use any of the filters you stated just as long as the diameter is the same on both the tube and filter. As for those velocity stacks I would assume that they would give more power... but its just an intake.</TD></TR></TABLE>
If they are not the same size, just get some cuplers and pipe clamps to get it to fit.
You will not notice a big gain with an intake, just more noise
