my DIY catch can for Bseries. non turbo
Old Dec 26, 2007 | 12:23 AM
tekstyle's Avatar
Default my DIY catch can for Bseries. non turbo
will this setup work?
my goal is to keep the intake manifold as clean as possible. I don't have turbo. I used to have a DIY catch can, but it did not have a return line so i have to periodically empty it. also, it was never hooked up to the valve cover.
Old Dec 27, 2007 | 10:14 AM
tekstyle's Avatar
Default Re: my DIY catch can for Bseries. non turbo (tekstyle)
anyone?
Old Dec 28, 2007 | 07:32 AM
chrisbmx68's Avatar
I wouldn't run the breather from the block directly to the drain, I would run it from the block to the catch can. I also wouldn't run a vac line on the catch can I would just use an open filter.
Old Dec 30, 2007 | 01:36 AM
tekstyle's Avatar
Default Re: (chrisbmx68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisbmx68 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't run the breather from the block directly to the drain, I would run it from the block to the catch can. I also wouldn't run a vac line on the catch can I would just use an open filter.</TD></TR></TABLE>
can you please explain why not to run breather from block to drain? and also why use an open filter than a vac line? from my understanding, everything goes back to the crank anyways so i don't understand why block to drain is not a good idea. thank you.
Old Dec 30, 2007 | 07:53 AM
LPED's Avatar
don't run hose from value cover to can, that needs fresh air (not intake manifold).
When your in WOT vacuum will be near 0 inches, your not going to get good breathing there, run it to intake hose (aircleaner-throttle body) or just add small filter on it if you have no MAF sensor.
Ed
Old Dec 30, 2007 | 05:03 PM
tekstyle's Avatar
Default Re: my DIY catch can for Bseries. non turbo (LPED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LPED &raquo;</TD></TR><TR><TD CLASS="quote">don't run hose from value cover to can, that needs fresh air (not intake manifold).
Ed</TD></TR></TABLE>
thanks Ed.
Old Dec 31, 2007 | 06:27 AM
chrisbmx68's Avatar
I wasn't saying you shouldn't drain the can back to the crank, just that you should vent both lines to the can then have it drain back to the crackcase.
Old Jan 1, 2008 | 10:55 PM
tekstyle's Avatar
thanks guys. gonna start working on it in a few days then.
Old Jan 2, 2008 | 08:31 AM
dinko's Avatar
Default Re: (tekstyle)
that **** looks confusing as hell...5 hoses? my setup im running 2 hoses from the back of the block with no drain back...just gotta empty it out every so often.
seriously were you high when you thought of all this? bored?
Old Jan 2, 2008 | 12:22 PM
tekstyle's Avatar
Default Re: (dinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko &raquo;</TD></TR><TR><TD CLASS="quote">that **** looks confusing as hell...5 hoses? my setup im running 2 hoses from the back of the block with no drain back...just gotta empty it out every so often.
seriously were you high when you thought of all this? bored? </TD></TR></TABLE>
what's wrong with a little critical thinking and analyzation? My motor is out of the car, I was able to clean and port my intake manifold. so I want to garantee the runners as clean as I can. is that a problem?
Old Jan 7, 2008 | 04:25 PM
A-'s Avatar
A-
Default Re: (dinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko &raquo;</TD></TR><TR><TD CLASS="quote">that **** looks confusing as hell.. </TD></TR></TABLE>
Old Jan 8, 2008 | 12:23 PM
tekstyle's Avatar
Default Re: (A-)
haha. sorry guys. basically... i want the breather and the block PCV to go to the catch can through one openning. then relieve the pressure from the catch can to the intake manifold. and have a drain back to the OEM PCV blackbox.
B20vtec veteran
Sep 19, 2013 01:33 PM
SurferDude905
May 26, 2009 07:23 PM
Outkast95LS
Apr 21, 2008 08:35 PM
Samuels
Nov 28, 2007 04:39 PM
912
Feb 11, 2006 07:34 PM
