Catch Can Confusion
Old May 26, 2009 | 06:07 PM
SurferDude905's Avatar
Default Catch Can Confusion
I've read the many threads on here that there are about catch can set-ups. Still a little confused on how to run my set-up.
I have a greddy style catch can with 2 fittings on the top of it. So will I be okay if I remove the entire pcv, block off the hole in the block where the black box use to be and then block off the fitting on the intake manifold where the pcv line use to run. Then run 2 -10AN fittings from the front of the valve cover to the catch can?
Is this correct. This is just a mild build nothing serious. Not looking for longevity or the best set up. I just need something to last me the summer.
Thanks.
Old May 26, 2009 | 06:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Catch Can Confusion
if you are using the 2 ports on the can and run the vc vents to those 2 you have no where for the pressure to go.
you will have to add a breather.
Old May 26, 2009 | 07:06 PM
So if I put a fitting in the catchcan with a filter, then this set up should do the trick?
Old May 26, 2009 | 07:08 PM
90sedan's Avatar
Yep, add a breather with filter to the catch can and that set-up will work.
Old May 26, 2009 | 07:09 PM
Awesome. Thanks! And as far as the lines go. I can just use brass fittings with rubber lines?
Old May 26, 2009 | 07:17 PM
90sedan's Avatar
Honestly, anything works. The fancy an fittings and steel braided lines aren't necessary, but look much nicer than brass fittings and rubber hose.
Use whatever you can afford.
Old May 26, 2009 | 07:23 PM
cleansi's Avatar
thought i would but in if its alright with you guys if your done but does any 1 kno how hard it would be to remove the old charcoal box using a catch can ive searched a lot and seen people still running both sorry to but in.
EusebioSam19
Dec 17, 2012 01:25 AM
dc2lsvtech
May 31, 2012 10:46 AM
TypeRMOBBiN209
21
Jul 26, 2011 01:31 PM
tekstyle
11
Jan 8, 2008 12:23 PM
Samuels
Nov 28, 2007 04:39 PM
