dumb question about springs
The tall ones should go in the back.
But push on them on the ground, The stiffer ones go in the front.
most of the time the stiffer ones are shorter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarFreek »</TD></TR><TR><TD CLASS="quote">The tall ones should go in the back.
most of the time the stiffer ones are shorter.</TD></TR></TABLE> i don't think he wants his ride to look like some mulet head camaro from the 80's, the tall springs in the front will make up for the light rear end of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote"> i don't think he wants his ride to look like some mulet head camaro from the 80's, the tall springs in the front will make up for the light rear end of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsdneil »</TD></TR><TR><TD CLASS="quote">tall goes in front. the engine has more weight and the springs need to compensate for carrying the load by making the spings taller so you dont bottom out.</TD></TR></TABLE>
I have Pro-Kits on my car. I Put the tall ones in the back.
It sits 1/2 in LOWER in the back than in front.
The short springs wouldn't even fit the back shocks. (about 2 in to short)
Did you two ever bother looking at a set of stock springs??
The back ones are taller.
The back use taller springs because it have more travel.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsdneil »</TD></TR><TR><TD CLASS="quote">tall goes in front. the engine has more weight and the springs need to compensate for carrying the load by making the spings taller so you dont bottom out.</TD></TR></TABLE>
The tall ones go on the back. They should be taller, but have more give when you push down on them. Take a look at stock ones and you will see..also, amny have a R or F in the aprt number signifying Front or Rear.
VTEC_Du_Ma_Mai
Dec 8, 2007 02:57 PM
jdmspoonitr
Feb 24, 2004 01:38 PM
