D16Y7 crank pulley
Old Dec 25, 2007 | 05:53 PM
rarrior23's Avatar
Default D16Y7 crank pulley
How hard is it to change out a crank pulley? I have a D16Y7 with the stock crank pulley and no AC or power steering and I want to get rid of the extra weight. I found a lightweight crank pulley on passwordjdm.com and was wondering how hard it was to change. Anybody changed one out before?
Old Dec 25, 2007 | 06:03 PM
slow_cx's Avatar
Default Re: D16Y7 crank pulley (rarrior23)
In my experience it differs a lot. I've had them come off easy, and i've had the bolt break off in the crank.. I suggest you use lots of PB Blaster. It's a penitrating oil found at any auto parts store. works wonders
Old Dec 25, 2007 | 06:09 PM
93baggedcivic's Avatar
pull the belt off and then get a 17mm socket(ibelieve thats what mine is)and get and impact gun on it or your not moving it before you do anything get the pb blaster and let it sit and soak it to no end and it should pop off it not you could tap it with a hammer or might have to get a puller
Old Dec 25, 2007 | 06:16 PM
rarrior23's Avatar
Default Re: D16Y7 crank pulley (93baggedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93baggedcivic &raquo;</TD></TR><TR><TD CLASS="quote">pull the belt off and then get a 17mm socket(ibelieve thats what mine is)and get and impact gun on it or your not moving it before you do anything get the pb blaster and let it sit and soak it to no end and it should pop off it not you could tap it with a hammer or might have to get a puller
Not to be rude, since you're helping me, but in english please.
Old Dec 25, 2007 | 07:34 PM
ddd4114's Avatar
It's not hard to replace the crank pulley. If you have penetrating oil and a long breaker bar, you should have little difficultly.
However, I would strongly recommend not using lighter one. That's probably not what you wanted to hear in this thread, but I thought I should throw it in.
Old Dec 25, 2007 | 08:08 PM
slow_cx's Avatar
Default Re: D16Y7 crank pulley (ddd4114)
True. The lighter pulley can throw off the harmonic balance of the crank. They don't like to make them heavy just for fun.
Old Dec 26, 2007 | 02:24 PM
rarrior23's Avatar
Hmm, based on that information, I'll wait 'til the summer. Thanks everyone.
Old Dec 28, 2007 | 01:35 PM
rarrior23's Avatar
Default D16Y7 D16Y8 differences
BTW, I just found out that I have a D16Y8, not a Y7. My dad and I were installing the carbon fiber hood I just bought and I looked at the engine block and it said D16Y8. I just assumed when I got it that it was a Y7, hmm. Now, can anyone tell me the differences between the two. Thanks.
Modified by rarrior23 at 3:23 PM 12/28/2007
civikdude
Feb 13, 2009 02:17 PM
twistedbydezign
Sep 24, 2005 02:10 PM
fe519
May 13, 2005 07:19 AM
duececoupe2
Feb 28, 2005 08:04 PM
HXvtec
10
Jan 1, 2004 07:26 PM
