Are You Knife Edged????
Old Dec 25, 2007 | 04:42 PM
kdawgy2k1's Avatar
Default Are You Knife Edged????
I was wondering if anyone is running a knife edged crank in there ALL MOTOR set as a daily driver???
And if you could please post a pic/some pics of your crank and any other input both postive and negative about using this style crank...
Old Dec 25, 2007 | 06:11 PM
93-lsvtec-eh2's Avatar
Default Re: Are You Knife Edged???? (kdawgy2k1)
con's are that sometime they chunk onder heavy loads and about the only pro is the little loss of weight
personally i'm not a fan of it i would rather just eliminate the oil squirters or just sand the roughnest off the crank with a sander to make it smooth. all your really looking for is to reduce the windage in the crankcase and there are better ways of doing that than knife edging the crank.
Old Dec 25, 2007 | 06:29 PM
soulpwr's Avatar
Default Re: Are You Knife Edged???? (93-lsvtec-eh2)
I've built 4 motors with knife edged cranks and daily driven the one in my motor. I'll try and dig up a picture. Pro's are lighter rotating assembly and a quicker revving motor. It takes a little more feathering to get away from a light though. I also run an 8lb flywheel too.
Old Dec 25, 2007 | 08:05 PM
lambertincorp's Avatar
Default Re: Are You Knife Edged???? (soulpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kdawgy2k1 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if anyone is running a knife edged crank in there ALL MOTOR set as a daily driver???
And if you could please post a pic/some pics of your crank and any other input both postive and negative about using this style crank... </TD></TR></TABLE>
how bout u stop bullishing and go turbo u know u want to
Old Dec 25, 2007 | 08:10 PM
kdawgy2k1's Avatar
Beautiful... I likey!!!! How much does that crank weigh??? both stock and after modified???
Old Dec 27, 2007 | 07:52 PM
soulpwr's Avatar
Default Re: (kdawgy2k1)
I dont remember the original weight of an ls crank but that one is 4 lbs lighter.
Old Dec 30, 2007 | 10:47 AM
machine4321's Avatar
in for more thoughts on it
turbotime
Mar 31, 2006 05:59 AM
EGcivicvtec
11
Jan 15, 2006 08:33 AM
B16A1-EF9
Nov 20, 2004 08:01 AM
wrXtian
Mar 4, 2003 03:09 PM
