98 civic EX front sway bar fit 98 civic DX?
im wondering if i get a 98 ex front sway bar will it just bolt up to my 98 dx? what would i need? do i need different LCAs?id like a list of parts id need to do this.Would a 2000 si front sway bar fit the same? 98 ex sway bar is 22mm si is 26mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">The front LCA's have the mounting point. All you need is the swaybar, endlinks and hardware (nuts and bolts)</TD></TR></TABLE>
Yeah, on DX and CX models they don't so you need to get the front lcas from swaybar equiped model like an ex or si for this to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">Does this apply to eg/eh2 as well?</TD></TR></TABLE>
I'm not sure but I think that all eg/eh have the same front lca, so I think that with those, if you have all the hardware, you can just bolt it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont »</TD></TR><TR><TD CLASS="quote">i just went an checked my LCAs and i dont have the hole for the sway bar and i check part number and the are different so i do need LCAs.</TD></TR></TABLE>
Right. Only the EX and Si trims have the correct LCAs from the factory.
For a Si bar you need Si lower control arms (and shock forks already mentioned), for a EX bar you need EX lower control arms. I would stay away from Si LCAs, because they lack mounting points for traction bars
Turbo_y8
Apr 26, 2007 03:26 PM
MugenManR
13
Feb 22, 2007 09:02 PM
vtec69
Nov 8, 2002 12:54 AM
