Little piece of LCA bolt wont come out.(tried everything!)
Old Dec 25, 2007 | 11:06 AM
maynards_ek's Avatar
Default Little piece of LCA bolt wont come out.(tried everything!)
So I had to cut the LCA bolt into 3 pieces just to get the LCA out. (1 cut on either side of the sleeve) Now all that is left is the 1/2 inch threaded end of the bolt that is still in the nut on the brake drum/knuckle assembly. I was able to leave a little piece hanging out when I cut the bolt initially. I have tried turning it with vice grips, but I keep slipping off that little piece. I then tried cutting a slot in to the piece and sticking a screwdriver in the slot to turn it, but I just stripped my makeshift slot out. My drill bits must suck, because they keep slipping off and wont bite. WTF am I supposed to do now?
Old Dec 25, 2007 | 01:33 PM
Crx Jimmy's Avatar
Default Re: Little piece of LCA bolt wont come out.(tried everything!) (maynards_ek)
Cut the nut off and just use a new grade 8 nut and lockwasher
Old Dec 25, 2007 | 06:45 PM
Default Re: Little piece of LCA bolt wont come out.(tried everything!) (Crx Jimmy)
Yeah, that was the last option I had entertained. Gonna go ahead and finish this project tomorrow. Thanks for the reassurance.
drsab2000
10
Mar 23, 2013 02:28 PM
Mr.Speed
Mar 13, 2008 04:09 AM
truevietluv636
11
Jun 6, 2007 07:13 AM
ak_teg92
16
Apr 30, 2007 04:40 PM
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
