LS VTEC PROBLEM!
i recently built my 1992 b18a b16a2 head. p30 ecu chipped- p30 dizzy- I used the golden eagle kit, had a machine shop plug the oil galley, brand new vtec solenoid and cant get vtec to work??? i've checked the wiring, oil pressure, ect! need some honda tech help.
I took it to get tuned, and the car not only dyno'd at 112 whp, it just revs out like
a normal ls no pull, no high cam switch point, no difference in sound. My last hatch was a ls vtec and vtec was abruptly noticable. the car was operating temp on dyno. anything else you can think of other then the wiring
Built bottom end, ctr pistons arp rod bolts knife edged crank. No vtec is not engaging and yes i should be pulling well into the 160's easy. the problem is the vtec solenoid is showing 12v at activation but engine doesn't switch over to high cam. what could be the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND0255 »</TD></TR><TR><TD CLASS="quote">Built bottom end, ctr pistons arp rod bolts knife edged crank. No vtec is not engaging and yes i should be pulling well into the 160's easy. the problem is the vtec solenoid is showing 12v at activation but engine doesn't switch over to high cam. what could be the problem?</TD></TR></TABLE>
I don't know the electronic parts of vtec, is it supposed to engage at 12v or something? Is the engine grounded properly from the valve cover? I don't know if it will help, but it might be worth trying
when i did my ls/vtec mine did the same thing. i found out i didnt have enough oil pressure. dont know if thats your problem but thought it might help. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND0255 »</TD></TR><TR><TD CLASS="quote">i recently built my 1992 b18a b16a2 head. p30 ecu chipped- p30 dizzy- I used the golden eagle kit, had a machine shop plug the oil galley, brand new vtec solenoid and cant get vtec to work??? i've checked the wiring, oil pressure, ect! need some honda tech help. </TD></TR></TABLE>
start with checking for codes you should find your answer there, and let us know
also check the FAQ thread at the top of the forum
