horrible grinding noise on the freeway yesterday.
Old Jun 28, 2002 | 09:04 AM
Fooser's Avatar
Default horrible grinding noise on the freeway yesterday.
So I was driving down the freeway on my way home from work when suggenly I hear this pop and a small grinding sound. Me being paranoid about every little sound I start to exit then suddenly bang and this horrible noise was coming from my drivers side. Then smoke came. I was like wtf so I pulled over as fast as I could. When I was able to inspect my car the entire splash guard that goes under bumper and wheel well was sticking out sideways in pieces. my rim was totally black from all the debree that came off. I was pissed to cause I tried to pull it out all the way and I couldn't get it loose due to my car being so low. Had to drive home with a plastic pieces sticking out of my wheel well. Guess it sounded bad but wasn't really.
Has this every happened to anyone? I bet this splashguard is going to be expensive. $$$
Old Jun 28, 2002 | 09:11 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: horrible grinding noise on the freeway yesterday. (Fooser)
I had the middle portion splashguard rip off when I drove over some ice. It wasn't expensive. I believe it was $38 for a brand new one from Acura. The side wheel guards should be the same or even cheaper.
Old Jun 28, 2002 | 09:22 AM
SamuraiJack's Avatar
Default Re: horrible grinding noise on the freeway yesterday. (shamoo)
passenger side guard cost 45+ at the dealer
happened to me before also
Old Jun 28, 2002 | 09:32 AM
Fooser's Avatar
Default Re: horrible grinding noise on the freeway yesterday. (SamuraiJack)
ya but I'm sure the lil bolts that hold it on cost like $5 a piece lol.
ok I will just pick up a new one. not worth my time to go to a salvage yard and get one.
Old Jun 28, 2002 | 09:34 AM
PM-Performance's Avatar
happened to me , i got the splash gaurd for like 40 somthing bucks from honda.
mine was the pass side. and they do give you the plastic bolts with it , , , at least mien did .
[Modified by itr206, 10:35 AM 6/28/2002]
Old Jun 28, 2002 | 12:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: horrible grinding noise on the freeway yesterday. (itr206)
man wtf, stealership here wanted $70+ for a new passenger side splash guard, mine was missing when I bought the car. I got one from evanshondaspecialist.com for $27 shipped, and they included the hardware because I was missing a few bolts. Used of course, but it was just a little dirt which I just cleaned off before installing.
Old Jun 28, 2002 | 12:58 PM
IN VTEC's Avatar
I've got a spare driver-side fenderwell liner you can pretty much have. It's got a couple of tears in it b/c it came off during an auto-x run, and got dragged a little. None of the mounting holes are damaged tho.
Shipping will probably be around $10, depending on how tight I can package it.
It is from a '95 Integra. I can't remember if the mounting point for the front is different tho.
[Modified by IN VTEC, 4:00 PM 6/28/2002]
Old Jun 28, 2002 | 01:14 PM
Default Re: horrible grinding noise on the freeway yesterday. (IN VTEC)
i dont think the 94-97 will fit the 98+ ones .. a little different
Old Jun 28, 2002 | 01:16 PM
Fooser's Avatar
There goes that idea. I'm sure my friend that owns a salvage yard will hook it up. If not I'm not too worried about it. The only thing I dont like is that you can see the hood cable if you look up in the fender.
So has anyone ever hooked up a pipe in there so that no one can splice your hood cable and steal your car that way? I was thinking some small electrical piping welded in then running my cable through it. Any ideas?
[Modified by Fooser, 10:18 PM 6/28/2002]
ramboPandA
Mar 23, 2015 08:41 AM
JDM94HATCH
11
Apr 14, 2007 03:55 PM
del sol1658
Jun 6, 2006 12:54 PM
Tuner Eddy
Mar 1, 2005 10:48 PM
FlatBrokeHatch
Sep 24, 2003 04:47 PM
