Si vs EX ??
Old Jun 28, 2002 | 08:47 AM
jjcivic_si's Avatar
Default Si vs EX ??
Can anyone tell me the performance specs (Hp & Torque) at each RPM level for both the Civic Si and the Civic Ex??
I know the Si has 160Hp and the Ex has 127Hp, but I want a more specific comparison.
Is it worth selling my Ex and buying an Si??
Thanks for your help.
Old Jun 28, 2002 | 08:52 AM
4g4me's Avatar
Default Re: Si vs EX ?? (jjcivic_si)
Ever concidered a swap? You can meet and well exceed the stock 99-00 si perofrmance with a b18c1 or a b16a. Cheap and easy alternate to buying an inflated SI
Old Jun 28, 2002 | 09:31 AM
Beave0101's Avatar
Honda Civic SI: 160hp, 111 Torque, 10.2.1 Compression Ratio
Honda Civic 2dr EX: 127hp, 107 Torque, 9.6.1 Compression Ratio
The SI weighs 2612, the EX weighs 2513, I think the weight is mainly in the engine, correct me if I'm wrong.
Other than just engine differences, SI has the lip and sideskirts(painted to say the least) different grille, gauges and seats are same but different covering, rear disc brakes, NO ABS while the EX does and a much improved transmission, yet still too small to handle larger HP applications stock.
I'd reccomend a swap, go total sleeper, I would opt for a B18 or an LS/Vtec, the differences between the GS-R and the SI's engine would be displacement, but the SI has a better head. And this way you get ABS which i could have used last february...........
[Modified by Beave0101, 6:32 PM 6/28/2002]
Old Jun 28, 2002 | 09:52 AM
jjcivic_si's Avatar
Default Re: Si vs EX ?? (Beave0101)
So the Si does not have ABS on the front and the rear??
or it has ABS on the front but not the rear disks??
Old Jun 28, 2002 | 10:59 AM
-Darren-'s Avatar
i thought the si didn't have abs.
Old Jun 28, 2002 | 11:05 AM
YodaIsGod
Guest
Posts: n/a
Default Re: Si vs EX ?? (blkgti)
USDM Si = no abs
CDM SiR = has abs
the suspension is slightly stiffer than the EX. bigger front sway bay, and a 13mm rear sway bar. Has the GS-R front strut tower bar.
15" wheels with 195/55R15 as the stock tire height.
Charlie Moua
Dec 12, 2013 08:23 AM
whiteciv88
May 9, 2008 03:38 PM
jeffG
Honda Civic (2006 - 2015)
Sep 13, 2007 10:38 PM
DCsports06
18
Feb 21, 2006 07:52 PM
Propulsion
Mar 26, 2002 03:51 PM
