00 SI Check Engine Light Problem
Old Dec 23, 2007 | 08:19 PM
em1mata's Avatar
Default 00 SI Check Engine Light Problem
I have this prob. w/ my car and I wuz' hopin' u guyz might b a able to help. When I'm racing in the fwy, if I'm on 5th, 4th or 3rd downshifting, the rpm doesn't reach 70,500, and my check engine light pops up, at that moment my vtec no longer works and it starts to smell like burnt gas. In order 2 get my vtec to start working I have to turn off my car and turn it on again 2 get the vtec working again. Later if I race it will do the same thing over again. I don't know what it is and it's frustrating, what do u guys think it is? What can I do? Thanks!!
Old Dec 23, 2007 | 08:21 PM
ifIexplode's Avatar
First, When the check engine light comes on, Pull over and jump the connector to see what code its throwing, then come back.
Old Dec 23, 2007 | 08:25 PM
em1mata's Avatar
Default Re: (ifIexplode)
Got ur email, I understand what ur saying but when the light pops up do I have to turn off the car or check it with my car on because the minute I turn off and on the car, the car goes back to normal, the check engine light no longer pops up. Thanks!
Old Dec 23, 2007 | 08:28 PM
ifIexplode's Avatar
You can do it with the car Running. Heres how.
https://honda-tech.com/zerothread/1901557
Old Dec 23, 2007 | 08:37 PM
em1mata's Avatar
I actually did try that out in the afternoon w/ the car off with P28 chip computer and it threw the code 7, which is TPS. I took off that computer and threw the stock comp. on and the check engine light remained on and it wouldn't do nothing. So should I try doing this again as soon as the check engine light goes on or do u think it's the TPS? Thanks!
Old Dec 23, 2007 | 10:45 PM
Hittnthebz's Avatar
Couldnt hurt to check it one more time. If you are planning on using the chipped ecu you may want to just go by what that ecu tells you tho cuz that is how your car will run on a day-day basis.
Old Dec 23, 2007 | 11:52 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (em1mata)
What mods do you have?
Are all your sensors accounted for and plugged in correctly?
If your ECU is throwing a code for a TPS, then...maybe you found your answer.
Put your stock B16A2 Si ECU back in. Go to autozone and have them flash whatever codes come up. Fix from there.
Eg_hatch_95
Mar 15, 2009 10:35 PM
ANONYMOUSdeecee
Dec 28, 2006 08:00 PM
jorge99hx
Nov 4, 2005 08:29 PM
B18Redline
Apr 7, 2004 08:01 AM
