my CHECK ENGINE light turns on while driving
Old Dec 28, 2006 | 01:50 PM
ANONYMOUSdeecee's Avatar
Default my CHECK ENGINE light turns on while driving
im havin a problem with this since i turn the key to on and theres no check engine....but after about 5 minutes while driving the car the light goes on....also runs kinda wierd after check engine light turns on......it a ls/vtec set up wit itr ecu
Old Dec 28, 2006 | 02:07 PM
mrdeadman's Avatar
They let me pick
Default Re: my CHECK ENGINE light turns on while driving (spoonJDMdctwo)
pull the code and post it.
or figure it out yourself: https://honda-tech.com/zerothread?id=978933
Old Dec 28, 2006 | 02:46 PM
cslegacy's Avatar
I had this problem im bad with cars but the light would come on and my car would start hopping it was the speedo cable was not in right.
Old Dec 28, 2006 | 08:00 PM
Default Re: (cslegacy)
I try pullin a code but it does not work since the light only turn on intill like 2nd gear......so its hard to pull the code...icant even run no one....since it bog really badlly
ryanminer
Oct 17, 2008 08:52 AM
Spartoons
Jul 9, 2007 05:44 PM
Corruption
Jun 3, 2006 12:08 PM
jorge99hx
Nov 4, 2005 08:29 PM
under_psi
Aug 16, 2001 12:50 PM
