will 96 coupe supsension fit on a del sol....
Old Dec 22, 2007 | 04:20 PM
lsvtechatch92's Avatar
Default will 96 coupe supsension fit on a del sol....
i know this is the wrong section ive searched... i have got no reply in suspension forum... need to know asap... bout to trade
Old Dec 22, 2007 | 09:49 PM
HiProfile's Avatar
Default Re: will 96 coupe supsension fit on a del sol.... (lsvtechatch92)
Maybe try in the civic section then?
I know the rear lca's won't work, but most of the rear will. I'd expect the front to bolt up, but I'm not sure if the lca's in front are different.
Old Dec 23, 2007 | 05:43 AM
coneheadsracing's Avatar
Default Re: will 96 coupe supsension fit on a del sol.... (HiProfile)
Is the del sol suspension the same as an eg? If so, the fronts should work, however from what i remember, the rears on an ek, are narrower then the eg. In other words, you have to trim the bushing, to put ek, on eg's. I believe the lca's are the same though, other then that. So if you swapped the lca's also, i think it would work? Or modify the bushings.
DelSolMike
Jun 30, 2013 01:53 PM
farfrumugen
Jun 11, 2010 05:50 PM
GotamaHuy
23
Apr 24, 2010 03:14 AM
OG SHG_EM1
Apr 6, 2006 04:49 PM
douspray
Apr 15, 2005 08:13 AM
