will 96 coupe supsension fit on a del sol....
i know this is the wrong section ive searched... i have got no reply in suspension forum... need to know asap... bout to trade
Re: will 96 coupe supsension fit on a del sol.... (lsvtechatch92)
Maybe try in the civic section then?
I know the rear lca's won't work, but most of the rear will. I'd expect the front to bolt up, but I'm not sure if the lca's in front are different.
Re: will 96 coupe supsension fit on a del sol.... (HiProfile)
Is the del sol suspension the same as an eg? If so, the fronts should work, however from what i remember, the rears on an ek, are narrower then the eg. In other words, you have to trim the bushing, to put ek, on eg's. I believe the lca's are the same though, other then that. So if you swapped the lca's also, i think it would work? Or modify the bushings.
DelSolMike
06-30-2013 01:53 PM
farfrumugen
06-11-2010 05:50 PM
GotamaHuy
23
04-24-2010 03:14 AM
OG SHG_EM1
04-06-2006 04:49 PM
