OBD2B to OBD1 Idle Problems
Old Dec 22, 2007 | 11:12 AM
SimplyTron's Avatar
Default OBD2B to OBD1 Idle Problems
I have a 00 EM1, I got a conversion harness and socketed p28. I'm running a P30 map. Everything runs fine no CELs or anything but my idle is like I have a vacuum leak. It goes from 1500 to 2000 back and forth. I think it may be the IACV and I looked up what I need to do but I'm confused because I was told to take B6 and move it to B23 But I already have the blk/blu wire at B23 and no B6. Any ideas?
Old Dec 22, 2007 | 11:18 AM
z6hatchboy's Avatar
you could try cleaning the iacv and see if that fixes it. if your not throwing codes then you wiring is probably fine on that.
Old Dec 22, 2007 | 06:18 PM
adamrg85's Avatar
just turn your idle down with the little flat head screw to the left of the map sensor, I had the same problem and it fixed it
Old Dec 22, 2007 | 07:45 PM
jasony0630's Avatar
76.26.106.124
i used to have that problem on my ej8, i even turned down the idle...but a new iacv solved it
Old Feb 9, 2008 | 01:32 AM
EKay89's Avatar
Default Re: (adamrg85)
how do you clean the iacv?
Old Feb 9, 2008 | 03:13 AM
slowcivic2k's Avatar
Default Re: (EKay89)
Unplug the IACV with the engine running, and see if the idle falls. If the ECU cannot command the IACV, it will throw a CEL, so I'm thinking you have a leak perhaps.
If your idle is still high, unplug the PCV hose on the intake and plug the manifold hole for it, and notice how your idle drops. This should make any leak easily audible, since the engine must suck harder to run.
If your certain you have no leak, reconnect the PCV hose, and leave the IACV disconnected. Then adjust the idle set screw with the engine fully HOT, to 450rpm. You've just set base idle speed. This speed with give the IACV it's most effective idle control range, to reduce and increase idle. Once the IACV is plugged in, your idle should bump to 700-750rpm. right where it is supposed to be.
If the idle does not improve within a few moments, the IACV plunger could be stuck. Two 10mm bolts hold it on the back of the intake manifold, simply undo these, and use brake parts cleaner to clean both of the holes in the IACV and allow it to dry. You can also use a pencil or other soft object to manually move the plunger to ensure it still moves. If this does not solve the problem, replace the IACV. At this point the IACV is receiving the commands, but cannot physically complete the job due to a defect or damage.
RinzEG6
Nov 24, 2014 12:02 PM
rx_86
10
Dec 28, 2008 09:14 PM
sick_dc2
Jul 8, 2008 12:02 PM
mikeunreal2
Mar 29, 2006 09:27 PM
Brian_92GSR
May 31, 2004 03:57 PM
