Gas Tank Issue
Old Dec 22, 2007 | 12:18 AM
riceforlife's Avatar
Default Gas Tank Issue
Hey all been doing winter work on my car. Anyways since its propped up I decided its a good time now to fix my gas tank. The problem is that its dented. Big dent. And I can only fill up my tank to 9.6 gallons instead of the 11.9. This dent also expletives with my gas meter too. Car is a 00 si.
So I was wondering.... If I wanted to go about taking a block of wood or something, and attemmpt to hammer out the dent from the inside, how would I go about doing this? (Remove back seats, fuel pump, anything else I need to know?) Thanks
Old Dec 22, 2007 | 01:28 AM
NOFX's Avatar
H-T White Ops
Default Re: Gas Tank Issue (riceforlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceforlife &raquo;</TD></TR><TR><TD CLASS="quote">Hey all been doing winter work on my car. Anyways since its propped up I decided its a good time now to fix my gas tank. The problem is that its dented. Big dent. And I can only fill up my tank to 9.6 gallons instead of the 11.9. This dent also expletives with my gas meter too. Car is a 00 si.
So I was wondering.... If I wanted to go about taking a block of wood or something, and attemmpt to hammer out the dent from the inside, how would I go about doing this? (Remove back seats, fuel pump, anything else I need to know?) Thanks</TD></TR></TABLE>
You don't.
The gas tank is enclosed. You need a new tank.
Old Dec 22, 2007 | 01:37 AM
civic.slow's Avatar
* B A N N E D *
strike an arc and weld in a new panel! JK!!!!!!!! don't do it.
death may occur, ya you have a plastic tank. just get a new one. should be like 500 bucks either that or find a shell............pleanty of em in socal.........offer the owner like 150 bucks and im sure he'll let you have it
Old Dec 22, 2007 | 01:43 AM
Syndacate's Avatar
Default Re: Gas Tank Issue (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
You don't.
The gas tank is enclosed. You need a new tank.</TD></TR></TABLE>
If you remove the fuel pump you have access to stick a piece of wood in the hole and bang the dent out from the inside - depending on where it is.
@ OP:
If I were you I'd leave it tf alone.
Not only is it going to be a big pain in the ***, especially if the dent's not perfectly centered on the bottom, but if it's not leaking now, just leave it be...
Old Dec 22, 2007 | 01:59 AM
NOFX's Avatar
H-T White Ops
Default Re: Gas Tank Issue (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
@ OP:
Not only is it going to be a big pain in the ***, especially if the dent's not perfectly centered on the bottom, but if it's not leaking now, just leave it be...</TD></TR></TABLE>
Of course, but I don't figure he'll be able to hammer a two gallon dent out from there. I would imagine it stretches out.
Not to mention I wouldn't want to put pieces of wood in the tank or damage the tank further.
Old Dec 22, 2007 | 02:27 AM
all righty then guess ill just leave it alone and average my 220 a tank
Old Dec 22, 2007 | 08:08 AM
ca-rs's Avatar
Leave it alone and think of it as saving $6 every fillup
Old Dec 22, 2007 | 09:23 AM
pdiggitydogg's Avatar
Get a different tank. The em1 tank is no different from any other 99-00 coupe/hatch, so find someone parting a civic and buy it.
I changed a gas tank 2 years ago - took an hour.
Old Dec 22, 2007 | 11:12 AM
NOFX's Avatar
H-T White Ops
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Get a different tank. The em1 tank is no different from any other 99-00 coupe/hatch, so find someone parting a civic and buy it.
I changed a gas tank 2 years ago - took an hour.</TD></TR></TABLE>
If it makes the OP feel better, all '99-'00 US Civics besides the GX (which the chances of you getting a GX fuel tank is slim to none) are the same part number even.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ca-rs &raquo;</TD></TR><TR><TD CLASS="quote">Leave it alone and think of it as saving $6 every fillup </TD></TR></TABLE>
Except you'd fill up again sooner and as of lately the fuel price is more the next time.
GSR in progress 96
Dec 2, 2007 09:20 AM
urafag
Jun 30, 2006 05:07 AM
bleedblue94
11
Apr 16, 2006 01:08 AM
VanHonda
Apr 14, 2005 04:03 PM
adaml2nv
Jun 6, 2004 04:50 AM
