Radiator question
Old Dec 21, 2007 | 06:23 PM
z6hatchboy's Avatar
Default Radiator question
So when i was pulling my motor the other day i cracked the upper neck on the radiator (dx eg, 5 spd.) I have a radiator from my buddies 95 ex auto, and i am thinking its dual-core because of the two small lines on the bottom for the trans. So when i put this in and fill it up, will it all leak out of the two bottom lines, or do they need plugged? Thanks.
Old Dec 21, 2007 | 08:03 PM
z6hatchboy's Avatar
bump before i go.
Old Dec 21, 2007 | 08:13 PM
Xscort's Avatar
if im not mistaken i believe that radiator is like you said auto, thats for the tranny cooler. It shouldnt leak. I did a auto to manual swap on my Escort and used the auto tranny. I just unhooked the lines and no leaks. The tranny fluid must flow around the fins and stuff. You should be fine.
Old Dec 21, 2007 | 09:13 PM
ca-rs's Avatar
Default Re: Radiator question (z6hatchboy)
It will not leak, that is a seperate brass coolant tank located inside the endcap of radiator for trans fluid. No need to cap them off.
Old Dec 21, 2007 | 09:14 PM
z6hatchboy's Avatar
Default Re: Radiator question (ca-rs)
Charlie Moua
Apr 26, 2023 02:47 PM
gold_pwr_r4ng3r
Honda Civic (2001 - 2005)
Apr 10, 2012 11:32 AM
RA61825
Sep 19, 2009 04:45 AM
6shootahorsenamedtrigga
Jun 1, 2007 04:09 PM
tolowhb
Jan 18, 2006 04:39 PM
