Tranny side stud for engine mount strips 17mm nut????
Old Dec 21, 2007 | 03:14 PM
stehigs321's Avatar
Default Tranny side stud for engine mount strips 17mm nut????
Putting some prothane bushings in and the rear stud post on the tranny side stripped the threads on the inside of the 17mm nut. Going to get some replacements now....Any idea of what could cause this?? stud looks fine and nut was going on straight....lmk thanks HT
Old Dec 21, 2007 | 03:17 PM
Luserkid's Avatar
Default Re: Tranny side stud for engine mount strips 17mm nut???? (stehigs321)
Probably rusted on and when you took it off it stripped. Or last time it was way over torqued.
Old Dec 21, 2007 | 03:19 PM
stehigs321's Avatar
Default Re: Tranny side stud for engine mount strips 17mm nut???? (Luserkid)
I tried both nuts...one for the front stud and the one from the back stud...both were fine then stripped trying to replace the nut. they went on the front stud fine...then when putting one on the rear stud, both stripped. again...this is the nut being stripped
Old Dec 21, 2007 | 03:21 PM
stehigs321's Avatar
cmon guys cant drive this until this nuts are on....
Old Dec 21, 2007 | 03:26 PM
Luserkid's Avatar
Get new studs then
Old Dec 21, 2007 | 03:27 PM
stehigs321's Avatar
why would i need to get new studs....first of all its only the rear one...wouldnt putting new studs on the tranny be a total pain??
Old Dec 21, 2007 | 09:49 PM
stehigs321's Avatar
Wow...so now my studs are pretty much stripped. Anyone know hard it will be to replace these studs???
stehigs321
Dec 22, 2007 09:21 AM
pinecone
May 29, 2007 12:30 PM
technine
Feb 1, 2005 05:40 PM
