Help with my gauges!
Id rather post it here to get more views.. so please help
So I get out of work last night, walk out into the rainy 75 degree atmosphere of lovely Florida, get into my lucky em2, turn it on and for some reason, as I hear the motor rev up to 1400 rpm, the Tach doesnt rev up. It stays at 0. Same with the water temp gauge, and the fuel gauge and the speedo. No signal. Not even the srs light came on, or my seat belt, un-clicked sign thing. Not even the Maint Req'd light that popped on a couple of days ago or the high beam indicator. However, cluster lights up just fine, turn signals show up.. what..the hell?? Any ideas on what could be wrong? This happened ONCE before, and I freaked out for a minute because I felt like Robert DeNiro in Casino and didnt want to explode. So I turned the car off..waited 30 sec, and started her up just fine.. This time, I tried everything. I even reset the ECU.. and it worked fine after that. But then i turned it off and came inside and when i came back out.. same issue.
Any ideas on what the issue could be? Please? Thanks.
emotionisdead
11
Aug 27, 2006 02:29 AM
HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachometer S
cpforyou
May 16, 2004 08:22 PM
