oil light, stuttering,b20vtec!!?? help please
Old Dec 21, 2007 | 09:58 AM
skUnK2jdm's Avatar
Default oil light, stuttering,b20vtec!!?? help please
Hey ht I got a question what's wrong with my car?.... I have a 97 ekhatch with a b20vtec iam running it off a chipped p72.
Well I drove it today and it was stuttering in low rpm, then it wouldn't rev past 4 and the oil light would come on for a second then dissapear. Wtf is going on?? Any advice will help thanks
Old Dec 21, 2007 | 10:18 AM
smileycvc's Avatar
Default Re: oil light, stuttering,b20vtec!!?? help please (skUnK2jdm)
You are low on oil. Your oil pump could be bad. You cracked a sleeve. At least check your oil first and let us know.
Old Dec 21, 2007 | 10:53 AM
skUnK2jdm's Avatar
Default Re: oil light, stuttering,b20vtec!!?? help please (smileycvc)
There's plenty of oil! And I did a comp check and was 270 across the board!
Old Dec 21, 2007 | 11:48 AM
skUnK2jdm's Avatar
Old Dec 21, 2007 | 02:38 PM
smileycvc's Avatar
Then maybe option number 3 oil pump.
Old Dec 21, 2007 | 02:43 PM
skUnK2jdm's Avatar
ok well i reset the ecu and stuttering went away. but the oil light filckers when iam downshifting or am at idle. but goes away when i press the gas
Old Dec 21, 2007 | 03:16 PM
archuletac's Avatar
oil pump.sorry.
Old Dec 21, 2007 | 03:42 PM
skUnK2jdm's Avatar
Default Re: oil light, stuttering,b20vtec!!?? help please (archuletac)
how can i check?
Old Dec 21, 2007 | 03:55 PM
skUnK2jdm's Avatar
my oil sending unit is not hooked up can this be the problem?
Old Dec 21, 2007 | 04:07 PM
smileycvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">my oil sending unit is not hooked up can this be the problem?</TD></TR></TABLE>
Ya think?
Old Dec 21, 2007 | 04:10 PM
skUnK2jdm's Avatar
but wouldnt the oil light be on all the time?
Old Dec 21, 2007 | 04:24 PM
skUnK2jdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">but wouldnt the oil light be on all the time?</TD></TR></TABLE>
Old Dec 21, 2007 | 05:24 PM
sohctodohc's Avatar
ya the oil sending unit on the back of the block is just a dummy light. im confused on how the light isnt on at all times.
do you have a oil pressure gauge? if not i would invest in one. see what it is. if it seems low i would probably change oil pump.
what kind of oil what weight and what filter are you using???
Old Dec 21, 2007 | 06:48 PM
skUnK2jdm's Avatar
Default Re: oil light, stuttering,b20vtec!!?? help please (sohctodohc)
Yea its retarded the light is on when iam idleing and downshifting
I use mobil1 oil
Old Dec 21, 2007 | 08:10 PM
skUnK2jdm's Avatar
Old Dec 22, 2007 | 08:03 AM
sohctodohc's Avatar
well its not good when the light comes on cause i wanna say its trigered to come on when u only have like 7psi of oil pressure. but yours isnt plugged in.
i would either get a oil pressure gauge and see where your at on psi at all times(which can never hurt), or you can blindly start throwing money at it starting with the oil pump.
itzyaboyzeem03
Jul 1, 2016 04:40 PM
acuraman08
Apr 3, 2008 07:04 PM
95_red_dc
Apr 2, 2008 06:17 PM
DC_RaceR
Feb 23, 2006 02:00 PM
monalisa overdrive
Aug 6, 2003 01:40 PM
