Clutch "slips" from 3k-4k?
Old Dec 21, 2007 | 09:32 AM
preludedriva's Avatar
Default Clutch "slips" from 3k-4k?
It might have been doing this all of the time, so I dono
Anyways heres the story...
When i floor it in like 2nd, 3rd, or 4th gear and at 3k the rpms seem to go up way faster until around 4k then it seems to accelerate normal after that at full throttle still
im not sure if its actually slipping cause i can take my car up 9k without slipping
it still grabs good when i shift into 2nd from 1st at 8.5k
could it be my setup or something?
poor man r with ctr pistons s2s2 cams
exedy stg1 clutch maybe 6k on it? 11 lb flywheel same mileage
Old Dec 21, 2007 | 09:59 AM
Specail Ed's Avatar
Default Re: Clutch "slips" from 3k-4k? (preludedriva)
Are you sure your tires aren't spinning?
Old Dec 21, 2007 | 10:02 AM
Default Re: Clutch "slips" from 3k-4k? (Specail Ed)
in 4th? i grab at 8.5k still in 2nd still
Old Dec 21, 2007 | 10:17 AM
Specail Ed's Avatar
Did you try to bleed it at all?
Old Dec 21, 2007 | 10:20 AM
bleed what? the clutch mc? i had to replace a few days ago yes why?
Old Dec 21, 2007 | 12:19 PM
Specail Ed's Avatar
The slave cylinder on the transmission. If you just replaced the master cylinder and just dumped fluid in, you'll have to bleed the line. The air in the line could be causing you're slippage.
Old Dec 21, 2007 | 02:49 PM
i did bleed the line
thats how i am able to still shift
jdm_phunk
Feb 27, 2011 05:17 PM
ckinne
Apr 1, 2009 09:53 AM
ludelvr
Sep 12, 2003 04:20 AM
allmotorls95
Feb 26, 2003 01:30 PM
Rory Breaker
Oct 21, 2001 11:12 PM
