installing axleback help
Old Dec 20, 2007 | 01:09 PM
Tensa_Zangetsu's Avatar
Default installing axleback help
hey today i just bought a 98 civic stock axleback. right now i need some steps on how to remove the axleback and install the one i bought plz help. I attempt in doing it for 10 mins but then it rain so i had to stop. The tools i was was a 15mm ranch and pb blaster to loosen the bolt but it wouldnt budge when i tried to unbolt it.
Old Dec 20, 2007 | 01:12 PM
ttk3's Avatar
Default Re: installing axleback help (Tensa_Zangetsu)
unbolt it using whatever size wrench is needed. Pb blaster will help if its corroded. once the bolts are off pull the exhaust apart, and wrangle the hangers off the car. THen stick it back on the same way. It's pretty straightforward.
Old Dec 20, 2007 | 01:31 PM
i tried doing that but those 2 bolts wouldnt even move instead each time i use strength the pipe starts moving instead and im afraid my strength will be too much for it.
Old Dec 20, 2007 | 06:53 PM
can somone tell me an easy way or method to remove the 2 bolts from the axleback?
Old Dec 20, 2007 | 06:56 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Tensa_Zangetsu)
soak them in pb blaster and get an impact wrench.
Or buy new bolts and grind off the old ones.
That's about your only options.
Old Dec 20, 2007 | 07:17 PM
RiceKillinSI's Avatar
If you can't get a hold of a impact wrench, go get a longer breaker bar. The longer the bar the more leverage you put on the bolt. Looks something like this:
http://www.amazon.com/Drive-Me...r=8-3
Just keep trying, sometimes exhaust bolts can be a bitch.
Old Dec 20, 2007 | 07:29 PM
thxs for all the tips guys. imma be sure to try it all out during my spare time. ya Honda-tech peep are awesome, really appreciate it.
White V6
Aug 3, 2005 08:19 AM
MI4$DC5
19
Apr 2, 2005 09:10 AM
GSRerrr
Mar 4, 2005 08:50 PM
GSRerrr
Nov 14, 2004 08:19 PM
RotiEatter
Mar 2, 2004 04:36 PM
