help installin cat-back
Old Nov 13, 2004 | 09:08 PM
GSRerrr's Avatar
Default help installin cat-back
hey i got greddy evo2 on my 2000 GSR everything should b pretyy straight forward?
Old Nov 13, 2004 | 09:10 PM
Ti3d in's Avatar
Default Re: help installin cat-back (GSRerrr)
Yep. Some bolts might be a pain to get out, so use an impact wrench. WD-40 will help get the rubber hangers out.
Old Nov 13, 2004 | 09:16 PM
Vi3tboy's Avatar
should be cake. i have a 96 teg living in mn all its life and i went to change my exhaust this last week and everything came out easy.
Old Nov 13, 2004 | 09:48 PM
debogsr's Avatar
Default Re: (Vi3tboy)
Take off the axel back before removing the whole catback. I would remove the bolts before removing the hangers also. But i guess it doesnt matter.
Old Nov 13, 2004 | 10:49 PM
sabotage7's Avatar
just soak your bolts in some PB Blaster and you'll be fine.....an impact wrench is always nice if you have access to air tools......and if you know someone w/a lift, that always makes things easier! thats how i did mine anywayz!
Old Nov 14, 2004 | 07:27 PM
GSRerrr's Avatar
Default Re: help installin cat-back (sabotage7)
thanx alot every1
Old Nov 14, 2004 | 08:19 PM
boosted k20's Avatar
the 3 bolts that mount the catback to the catalytic converter are usaully rusted. u might need to heat them up, then take a socket and hammer it on there. then u should be able to turn the bolt. hardest part in install n a catback it get n off the rusted bolts
Tensa_Zangetsu
Dec 20, 2007 07:29 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
White V6
Aug 3, 2005 08:19 AM
GSRerrr
Mar 4, 2005 08:50 PM
jweezy225
Jun 19, 2004 06:33 AM
