help...car misfire on idle
as title, car is a 94 honda accord ex. i have replace injectors, fuel pump, distributor, spark plugs and wires and clean egr ports. i just dont know what eles that will cause this miss on idle. can any of the egr unit cause this???
the EGR system is not active at idle.
Vacum leaks?
You can pull one plug wire at a time from the dist cap to see if you can isolate which cylinder is dropping out.
Vacum leaks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">the EGR system is not active at idle.
Vacum leaks?
You can pull one plug wire at a time from the dist cap to see if you can isolate which cylinder is dropping out.</TD></TR></TABLE>
no vacuum leaks. each wire pull out drop out the same.
Vacum leaks?
Grab up your room mates toothbrush and a can of Berrymans B-12 carb cleaner, scrub out around the throttle plate, then you can also pop off the IACV and blast it out with the cleaner, and compressed air.
Pull off the vacum line to the fuel rail pressure regulator to check for raw gas in the line.
A quick way to clean injectors is to run the RPM up to around 4000 then pinch off the vacum line at the regulator with needle nose pliers and let the throttle drop back to idle. [high pressure flush] then let go of the vacum line.
Punker1234
13
Aug 6, 2005 06:07 PM
