getting pretty pissed off already
Old Dec 20, 2007 | 08:08 AM
civicEXtreme's Avatar
Default getting pretty pissed off already
Ok, so I have this socketed ecu, the first chip I had can idled fine and ran fine but wouldn't go over 4000 rpms, this new chip I just got the car won't even start!
But the car runs perfect on the stock ecu and carrys out the rpms like it should. What the hell could be wrong??
Old Dec 20, 2007 | 08:40 AM
are they just bad burns or something?
Old Dec 20, 2007 | 08:53 AM
h22crxpwr's Avatar
Default Re: (civicEXtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicEXtreme &raquo;</TD></TR><TR><TD CLASS="quote">are they just bad burns or something?</TD></TR></TABLE>
probably.
Old Dec 20, 2007 | 10:06 AM
my buddy told me it may be because uber isn't all that great some times. He said he went through two chips before switching to crome and crome worked fine.
Old Dec 20, 2007 | 08:16 PM
bump
Old Dec 20, 2007 | 08:59 PM
patrick4588's Avatar
go get tuned and quit using best guess chips
Old Dec 21, 2007 | 07:17 AM
Default Re: (patrick4588)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">go get tuned and quit using best guess chips</TD></TR></TABLE>
How? I need a base map for that...
Old Dec 21, 2007 | 04:10 PM
spun Vtec's Avatar
when the stock chip is in the car does it run fine?
Old Dec 21, 2007 | 04:20 PM
Default Re: (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">when the stock chip is in the car does it run fine?</TD></TR></TABLE>
they stock ecu? Yea... But I don't wanna run boost on the stock ecu. And the only place to get it tuned is like 2 hours away.
Old Dec 21, 2007 | 04:32 PM
spun Vtec's Avatar
No the stock chip in the socketed ecu. The ecu could have been damaged when it was socketed.
I would put the stock chip in the socketed ecu to make sure the ecu is ok.
Old Dec 21, 2007 | 04:55 PM
91_LS's Avatar
i have a 88 civic dx and im going to put a si intake on it but need to know how to do it and how much HP im going to get. im new to this page and dont know what to do yet so if you can help me send me a e-mail to kialeh@hotmail.com. thanks
Old Dec 21, 2007 | 05:42 PM
uhhh stock chip?
Old Dec 21, 2007 | 05:43 PM
Default Re: (kialeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kialeh &raquo;</TD></TR><TR><TD CLASS="quote">i have a 88 civic dx and im going to put a si intake on it but need to know how to do it and how much HP im going to get. im new to this page and dont know what to do yet so if you can help me send me a e-mail to kialeh@hotmail.com. thanks</TD></TR></TABLE>
Start your own damn thread!
Old Dec 22, 2007 | 09:07 AM
so basically you are telling us you want a best guess chip to run on a untuned turbocharged vehicle. thats real smart. run on the stock ecu to drive to your tuner. be mature and dont drive like an asshat there. drive only in vacuum. get tuned and then beat on the car.
Old Dec 22, 2007 | 09:19 AM
atec's Avatar
and take out your WG spring, that way you will never see anymore boost than atmospheric pressure. no matter how hard u try.
Go get your car tuned. you and your engine will be glad after a good tune
Old Dec 22, 2007 | 09:40 AM
Default Re: (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec &raquo;</TD></TR><TR><TD CLASS="quote">and take out your WG spring, that way you will never see anymore boost than atmospheric pressure. no matter how hard u try.
Go get your car tuned. you and your engine will be glad after a good tune </TD></TR></TABLE>
Good point, Or I could pop off a intercooler pipe. So I can't see boost.
Old Dec 22, 2007 | 11:55 AM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicEXtreme &raquo;</TD></TR><TR><TD CLASS="quote">uhhh stock chip? </TD></TR></TABLE> Yeah did I studder? you can put your stock chip in to the socket of your ecu.
Old Dec 22, 2007 | 01:07 PM
atec's Avatar
I would rather prefere taking out the wastegatespring, if you only "pop off" your IC piping, the turbo can be damaged by over reving.
Old Dec 22, 2007 | 08:13 PM
zuum's Avatar
solid cel? did you check the mil?
Old Dec 22, 2007 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote"> Yeah did I studder? you can put your stock chip in to the socket of your ecu.</TD></TR></TABLE>
There is no stock chip. Or I have none.
turboteg90
Sep 10, 2007 05:15 AM
civic_saints1
Jul 23, 2007 09:28 PM
THEUSED
Mar 12, 2006 01:30 PM
ahthisguyhere
Mar 8, 2006 04:22 PM
shocker
Nov 26, 2005 05:39 AM
