D16Z6 rod question z6/ls rod
hey im starting my turbo build and i bought a motor freshly rebuild d16z6 for NA, i took the rods and pistons out. are there any aftermarket stronger rods out there for that motor that does not involve taking the crank out? i just dont want to take it out to notch the block. or can i use stock LS rods without notching the block? thanks
It's not a smart idea to try and notch the block with the crank in. There is a shitload of metal dust that you will not be able to get off the crank. Do it the right way and tear the block down to nothing, notch it, clean it well, then reassemble. You can use LS rods without notching the block but they need machining.
well i just wanted to get the motor in the car asap and the motor is the only thing holding me back so i was just wondering if u could just put the LS rods in and be done but if not then im just gona buy some eagle rods in and b done.
boosted honda
Apr 14, 2006 09:05 AM
turbosi03
May 25, 2004 02:02 PM
