windows are slow goin up and down.
Old Dec 20, 2007 | 06:09 AM
MiracleWhip's Avatar
Default windows are slow goin up and down.
the ej8 needs work.
the window motors seems abit groggy going down and especially going up. this first begun with the passenger window button. the driverside passenger window button still worked- so i thought it was something i could hold off with. it now is happening to my driverside. i was like hell no.
Its cold up in jersey nowadays. i thought the cold had something to do with it. has anyone else experienced this. any help is appreciated.
Old Dec 20, 2007 | 06:13 AM
De_tour's Avatar
Default Re: windows are slow goin up and down. (MiracleWhip)
They either need lubrication in the channels or new regulators.
Try the cheapest method and use silicone lubricant first and if that dosent do it then its the regulators.
Old Dec 20, 2007 | 06:56 AM
Default Re: windows are slow goin up and down. (De_tour)
thanks de_tour. does the window have to be out its track or can i lube it with the window still in it?
Old Dec 20, 2007 | 07:17 AM
Relic1's Avatar
with them in the track works fine. Just spray it into a rag then wipe it into the channel. You may have to do it multiple times, it lubricates and cleans at the same time.
Old Dec 20, 2007 | 07:24 AM
96electronH's Avatar
yea my windows were solw as expletive goin up and down spray and wiped out with lubricant/penetrant and worked wonders
Old Dec 20, 2007 | 04:45 PM
Default Re: (96electronH)
nice. i'll do that.
Old Dec 20, 2007 | 04:49 PM
db8db8db8's Avatar
Default Re: (MiracleWhip)
how old is your car? is your weather stripping cracked or old?
Sean @ ESG
14
Sep 9, 2005 09:21 PM
samson1
Jun 21, 2004 08:35 AM
Matt B
Jan 14, 2004 08:50 AM
EX-T
Nov 27, 2003 07:26 AM
