I am having some awful luck!
I am still tring to fing the leak into my car. I finally got the energy to pull up the carpet and look deep.
Here is where the bad luck fell upon me..
Not only did i not find the leak.. I look up to see that my shop lights i had set up got my cold sunroof hot enough to crack the damn thing!!!
Now I have one more damn thing helping water get into my car!
Does anyone know where i can get a used or new glass Cheap Quick?! For a 93' Si hatchback
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angel_i »</TD></TR><TR><TD CLASS="quote">hey bud, i may be able to get you one from a eg coupe w/ sunroof</TD></TR></TABLE>
does that coupe have a d16z6 in it or just the d15b7??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angel_i »</TD></TR><TR><TD CLASS="quote">hey bud, i may be able to get you one from a eg coupe w/ sunroof</TD></TR></TABLE> I am very interested! See what you can do!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">have you tried doing a "leak test" by pouring water on the outside?</TD></TR></TABLE>I Live in utah and it has been snowing like crazy so i will find out soon enough. I don't want to find out if it leaks or not. I just want it fixed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_cx »</TD></TR><TR><TD CLASS="quote"> I am very interested! See what you can do!
I Live in utah and it has been snowing like crazy so i will find out soon enough. I don't want to find out if it leaks or not. I just want it fixed. </TD></TR></TABLE>
The test isn't to find out if it leaks or not. It's to find out WHERE it's leaking from. Find out where the water is getting in in the first place. Where it ends up isn't as much of a concern.
For example, you can have a leak at the top of your rear window in a coupe or sedan, but it first appears to you in the car around the trunk. Then you want to repair the leak near the window. You don't want to seal it off near the trunk so that you end up with a lot of water in between there.
ChampWhiteTegra
Apr 30, 2006 06:20 PM
