need help .... bad wheel viberations
Old Dec 19, 2007 | 07:50 PM
b16greenmachine's Avatar
Default need help .... bad wheel viberations
i took my car in to get my tires rebalanced and they said i need new wheels because my rims were bent... so i bit the bullet and paid the 600 to get new rims... but the problem didnt go away... i dont know what it is every time i get on the throttle around 50-and up the wheels fill like they are going to fall off.. any advice works...
99 hatch with b16a2 swap
Old Dec 19, 2007 | 07:54 PM
EJ8 944's Avatar
Default Re: need help .... bad wheel viberations (b16greenmachine)
have you had an alignment? it vibrates under accel/cruise and not braking correct?
Old Dec 20, 2007 | 09:46 AM
CtREK9's Avatar
Default Re: need help .... bad wheel viberations (EJ8 944)
yea if its not the balencing issue its going to have to be the alignment
Old Dec 20, 2007 | 09:51 AM
STDClayton's Avatar
Default Re: need help .... bad wheel viberations (CtREK9)
It could also be your Inner CV axle boot(s). Check to see if they're torn/ripped.
Old Dec 20, 2007 | 01:16 PM
it vibrate when i accel only not when im cruising or in nutural... and im goign to go check my cv axle boot right now
Modified by b16greenmachine at 3:20 PM 12/20/2007
homer_eps
Suspension & Brakes
Mar 10, 2008 08:46 PM
Shaguar47
12
Mar 28, 2007 08:50 AM
k_lude
Dec 14, 2006 09:34 AM
black sohc civic
Jan 24, 2005 02:27 PM
Hazzo
Jan 24, 2005 09:57 AM
