Car accellerates very slowly help!
Old Dec 19, 2007 | 06:39 PM
creepy116's Avatar
Default Car accellerates very slowly help!
hey i just swapped an itr motor in my car but for some reason the car accelerates very very slow. after i step on the gas it takes a few seconds then the rpm will start to move. i have to high rev it to about 3-4 to get it moving but when i let go of the clutch i have to like step on the gas all the way then the car will start moving very slowly.
Old Dec 19, 2007 | 06:42 PM
boostedNOTHARDLY's Avatar
out of time. period.
Old Dec 19, 2007 | 06:43 PM
creepy116's Avatar
Default Re: (boostedNOTHARDLY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedNOTHARDLY &raquo;</TD></TR><TR><TD CLASS="quote">out of time. period.</TD></TR></TABLE>
what does that mean?
Old Dec 19, 2007 | 06:44 PM
crazyguy's Avatar
Default Re: Car accellerates very slowly help! (creepy116)
any cel?car idel normal? spark plug wires firing order ?throttle body cable tight?
Old Dec 19, 2007 | 06:47 PM
creepy116's Avatar
Default Re: Car accellerates very slowly help! (crazyguy)
it is throwing a cel but i haven't checked on that, firing order is correct; if it wasnt then my car wouldn't start up, idle is ok, a bit below 1 rpm
Old Dec 19, 2007 | 06:51 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 &raquo;</TD></TR><TR><TD CLASS="quote">it is throwing a cel but i haven't checked on that, firing order is correct; if it wasnt then my car wouldn't start up, idle is ok, a bit below 1 rpm</TD></TR></TABLE>
i had mess up fireing order one time and car still starts up and drives.but it is slow as hell.
if idel is normal and firing order is correct.i think cel can be the issue.
Old Dec 19, 2007 | 07:18 PM
creepy116's Avatar
any other suggestions?
Old Dec 19, 2007 | 07:24 PM
xxtimlintxx's Avatar
no other suggestions.. haha check the cel
Old Dec 20, 2007 | 11:41 AM
mmafighter130's Avatar
hey man what the one guy meant is that your valve timing is off, the belt needs to be reinstalled, the #1 cylinder must be on TDC and the the marks on the cams need to be pointing up, there are also marks on the sides of the cam so you can line it up with the marks on the timing cover, check a haynes manual for instructions if not familiar with timing a car
Old Dec 20, 2007 | 04:12 PM
creepy116's Avatar
Default Re: (mmafighter130)
alright thanks guys ill check on that
Old Dec 20, 2007 | 04:19 PM
robert. tubb 111's Avatar
sounds like a slipping clutch
raphael
173
Jan 7, 2008 02:36 PM
civickiller
Aug 14, 2006 10:32 AM
beatthisspeed69
Apr 3, 2006 05:50 PM
Milk Man
10
Jun 13, 2005 03:17 PM
Btothe3rdDegree
Oct 30, 2004 10:33 PM
