hood latch won't work????????
Old Dec 19, 2007 | 03:44 PM
F20Cdriver's Avatar
Default hood latch won't work????????
thanks for looking first off, here is the problem, i pull the latch under the dash to open my hood but the cable is loose and will not open the hood. i even went under the fender to pull the cable with my hands and still no luck. i'm no small guy, so i know it's not lack of pulling effort. please help if you can and thanks again for looking!
Old Dec 19, 2007 | 04:48 PM
slacks's Avatar
Default Re: hood latch won't work???????? (F20Cdriver)
the cable on my ej is always loose, even since the replacement.
worse case i just jack the front end up and trip the latch
then you just need to find a better way to get your hood open lol
hope that helps
Old Dec 19, 2007 | 04:55 PM
jr000's Avatar
Default Re: hood latch won't work???????? (slacks)
the wire tubing pry cracked which is why it feels loose...but you want the wire to be tight...it happened to me...you will have to most likely take off your grill and pull yje wire on the latch with a set of needle nose pliers...and either get yourself a new hood release cable or fix the old one...depending on how bad it may be..
Old Dec 19, 2007 | 06:21 PM
F20Cdriver's Avatar
Default Re: hood latch won't work???????? (jr000)
thanks for the help guys i'll try that stuff as soon as i get a chance tomorrow.
Old Dec 19, 2007 | 06:25 PM
STDClayton's Avatar
On my EF I had to push down on the hood near the emblem/driver's side headlight with my left hand and reach in and pull the hood release latch. Try doing that. Hahaha.
Oh, and don't PULL your grill out. It's screwed in
Old Dec 19, 2007 | 08:36 PM
F20Cdriver's Avatar
Default Re: hood latch won't work???????? (STDClayton)
cool thanks
Old Dec 20, 2007 | 09:34 AM
CtREK9's Avatar
on my ej i had to put like a prop so it could hold the hood release up then open the hood it was because it was missing a small spring right on the hood latch hard to see but you can see if it missing or not that could be the prob
zhraan
Oct 9, 2018 06:46 AM
user 47646775
Jan 22, 2009 09:21 PM
turbotime
22
May 9, 2005 12:54 PM
jlv55
Oct 8, 2004 04:05 PM
88'CRX'Si
Sep 29, 2002 07:07 PM
