T1 G Force Shifter kit
Old Dec 19, 2007 | 11:03 AM
tony1's Avatar
Default T1 G Force Shifter kit
Hey guys, finally got all my pieces in for the G Force shifter kits. For those that don't know, what this shifter does is help prevent missed shifts. It has a spring inside that pushes the shift lever towards the 5/R gate. In order to get into the 5/R gate, you have to push down and over on the shifter. This helps prevent shifting from 2nd to 5th, but allows you to push all the way to the right on the 2/3 shift to minimize the chance of shifting back into 1st from 2nd. The 1-2-1 shift generally does a lot of damage!
The kits we've put together allow as bolt in of an installation as possible. The kits use high quality universal joints as well, not the cheap ones G Force sends with the shifters.
The installation involves removing the old shifter and linkage assembly completely. The hole in the chassis will need to be opened up slightly for the G Force shifter to fit through. The assembly slides up from the bottom of the car and you use the 2 factory 8mm bolt holes in the chassis that the OEM shift linkage bolted to. Then you will mark the 4 holes on the front side of the bracket and drill the chassis. You will then install the 4 8mm bolts from inside the car, they will thread directly into the bracket.
This setup requires 100% solid motor mounts for it to work right. Since there is no longer a stabilizer bar on the shift linkage, the engine can not move or it will try to pull the shifter out of gear. Avid and Hasport both offer solid mounts for most engine configurations. The fact that everything has to be 100% on the length of the shift linkage, since there's no stabilizer bar, means that we can not complete the linkage 100% before shipping. The linkage will be sent with everything complete except the last U joint at the trans. The tube going into the U joint will be left long and the installer will have to trim to length and either weld or bolt the joint/tube together while it's on the car. I will be putting together a PDF file with all the installation notes and instructions with pics shortly. The install is very straight forward and anyone with some basic tools can do the job.
Anyways, here's some pics, the kit comes complete with the G Force shifter, shift lever, shift ****, mounting bracket, and shift linkage. All hardware is included and it also comes with a new roll pin for the trans as well as the clip that goes over it.
Those of you who already have kits on order, they will ship next Wed. My supplier sent me the wrong size tubing for the linkages and it should arrive next Tues.
Thanks
Old Dec 19, 2007 | 11:05 AM
BoostedJeff's Avatar
Default Re: T1 G Force Shifter kit (tony1)
Jesus tony, always on top of it.
Just when people arent broke enough, you come out with this
Old Dec 19, 2007 | 11:07 AM
Day-DayC's Avatar
whats the price on this work of art?
Old Dec 19, 2007 | 11:09 AM
tony1's Avatar
Default Re: T1 G Force Shifter kit (Day-DayC)
This isn't a sales post, blah, blah, blah. lol
Info will by on my website soon.
Old Dec 19, 2007 | 11:13 AM
SpeedDreamz.com's Avatar
Tony can you make one for me? That is a beautiful piece tony, typical T1 quality.
Old Dec 19, 2007 | 11:24 AM
b16hybridsol's Avatar
Default Re: T1 G Force Shifter kit (rota92)
h/k love in the future?
Old Dec 19, 2007 | 11:33 AM
b18bturbo's Avatar
Default Re: T1 G Force Shifter kit (b16hybridsol)
looks aweseom tony
Old Dec 19, 2007 | 11:36 AM
Innes's Avatar
Default Re: T1 G Force Shifter kit (b18bturbo)
very nice as expected -- will be ordering soon
Old Dec 19, 2007 | 11:37 AM
buck02's Avatar
F#$king genius idea!!!!!
tony allways ontop as usual?
Keep it up all te stuff that comes from your shop is top notch
Old Dec 19, 2007 | 11:42 AM
2 0 3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Can't wait to see pics when I get home from work either! </TD></TR></TABLE>
haha me too! boooo work firewall!
Old Dec 19, 2007 | 11:48 AM
turbotypeR@SPEC's Avatar
25 Year Member
nice!
b18avtec(A!!M0TOR)'s Avatar
Default Re: T1 G Force Shifter kit (2 0 3)
WOW very nice
Old Dec 19, 2007 | 12:05 PM
MeanGreenMachine's Avatar
Default Re: T1 G Force Shifter kit (b18avtec(A!!M0TOR))
wow!!!
what a very well made quality piece of art!
Old Dec 19, 2007 | 12:06 PM
melovesboost's Avatar
BALLLLLLIN!!!! Whats the matter tony got tired of welding your T1 sig? lol LOoks badass but solid motor mounts arent cool on the street car
Old Dec 19, 2007 | 12:23 PM
tepid1's Avatar
Can't wait for next Wednesday. lol
Thanks again Tony.
I'll post up pics of the install.
Also do you have a better pic of the piece that mounts to the drive shaft of the Long shifter assembly?
Old Dec 19, 2007 | 12:26 PM
wHOAlly's Avatar
up for Team Losi
Old Dec 19, 2007 | 12:38 PM
Default Re: T1 G Force Shifter kit (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">up for Team Losi </TD></TR></TABLE>
What are you not an Associated man? I was a Losi man too.
Old Dec 19, 2007 | 12:40 PM
tony1's Avatar
Default Re: T1 G Force Shifter kit (tepid1)
Also, some people have asked, this can be used on a stock trans or an aftermarket gear set, you do not have to have a dog engagement gear set for this to work.
Here's another shot of the adjustment point on the shift linkage. There is a male/female socket between the two to locate them, the bolts are just to lock down the adjustment.
Old Dec 19, 2007 | 12:42 PM
I assume the plate mounts topside?
Old Dec 19, 2007 | 12:44 PM
tony1's Avatar
Default Re: T1 G Force Shifter kit (SpeedDreamz.com)
No, plate mounts under the car. The two 8mm holes in the rear bolt up to the oem shifter mounting holes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">No, plate mounts under the car. The two 8mm holes in the rear bolt up to the oem shifter mounting holes.</TD></TR></TABLE>
cool so the shifter is about stock height?
Old Dec 19, 2007 | 12:52 PM
tony1's Avatar
There are different length shift levers available from G Force. I supply the kits with thier longer lever, which puts the shift **** higher than the stock configuration. If you want it shorter, it can be cut and redrilled, it's just 2 bolts. I figure you can always make it shorter, but you can't easily make it longer, that's why i supply the long ones. Personally, i like the longer lever, gives you more leverage and puts the shift **** closer to the steering wheel.
Old Dec 19, 2007 | 01:05 PM
PHDZINE's Avatar
How is the bottom clearance for the people that are running 4.00" exhaust.
Old Dec 19, 2007 | 01:07 PM
tony1's Avatar
Default Re: T1 G Force Shifter kit (PHDZINE)
Clears my 4" exhaust with about .5" to spare, and my exhaust tucks up pretty tight.
Old Dec 19, 2007 | 01:11 PM
tepid1's Avatar
Now, it looks liek you would need to disassemble the shifter housing to mount the billet bracket. Do we need to worry about anything flying apart when we do so? (IE: springs)
Is the length of the shift linkage adjustable?
