What DP diameter from SC6152 4-bolt flange?
Old Dec 19, 2007 | 07:16 AM
Tjabo's Avatar
Default What DP diameter from SC6152 4-bolt flange?
I was intending to build a 3" DP, but this thing doesn't seem to want one. . . With standard wall-thickness aluminized 3", the bolts will barely fit beside the welds to weld the tube to the flange, even if I use allens. I could maybe just cut it really close, and then grind away from the welds a bit where I need to in order to make clearance for the bolt heads. Then I could use a stub DP off of the housing with a V-band to the rest of the DP. . .
Bottom line, at what point to I NEED a 3"? This is not going to be an all-out performance build, just a nice driver.
Thanks guys!
Old Dec 19, 2007 | 07:18 AM
PSI2HI's Avatar
Former Vendor
Default Re: What DP diameter from SC6152 4-bolt flange? (Tjabo)
Dent the pipe around the bolt holes
Old Dec 19, 2007 | 07:30 AM
Tjabo's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (PSI2HI)
Okay, can do!
So the 3" DP is pretty beneficial for power levels that aren't super high then, huh?
I kind of figured I wanted the big volume to help the spool, and especially since I plan to route in the wastegate dump.
By the way StraightLineSpecialties, NICE FLANGE! ! ! !
Old Dec 19, 2007 | 07:35 AM
twkdCD595's Avatar
you could dimple the pipe where the bolts go in or maybe use some allen head hardware.
Old Dec 19, 2007 | 04:58 PM
Tjabo's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (twkdCD595)
Are there any good threads or other resources that really lay out how you determine what size downpipe is necessary? It's an interesting topic to me at the moment.
Old Dec 19, 2007 | 05:19 PM
RCautoworks's Avatar
Most likely the sc61 4 bolt size is bigger then the normal garrett, but if its the same size, there is no way a 3 inch is going to fit on there. We had to do a 2.5 to 3 for this customer.
Old Dec 19, 2007 | 06:25 PM
Tjabo's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (RCautoworks)
Yeah, that is what I'm dealing with. . . Those parts are NICE!
Old Dec 19, 2007 | 07:15 PM
Cwest EK's Avatar
Like posted above, you will need to start with a 2.5" outlet 4-bolt flange (3" outlet 4-bolt flange is made to fit garrett gt-style turbine style housings) and run the 2.5"-3" reducer off the turbo to make the 3" downpipe work good luck
Old Dec 23, 2007 | 03:51 AM
91jdmhatchback's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (Cwest EK)
i think you guys are just making it harder for yourselves. it takes me 10 sec. to take a flat head screwdriver and dent the pipe slightly to fit a allen head bolt.
i have done this on every dp i have ever made.
Old Dec 23, 2007 | 04:51 AM
Tjabo's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">i think you guys are just making it harder for yourselves. it takes me 10 sec. to take a flat head screwdriver and dent the pipe slightly to fit a allen head bolt.
i have done this on every dp i have ever made.</TD></TR></TABLE>
I'll give this a try. If it doesn't work out, I'll drop back to one of the more elaborate approaches.
Thanks!
Old Dec 27, 2007 | 11:40 AM
twkdCD595's Avatar
I have this slightly smaller 4 bolt housing and full mandrel 3" piping from flange to flange. I can provide pics if ness. but it will fit, its VERY tight with the allens but I did not even have to dent the pipe.
Old Jan 1, 2008 | 05:34 AM
Tjabo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">I have this slightly smaller 4 bolt housing and full mandrel 3" piping from flange to flange. I can provide pics if ness. but it will fit, its VERY tight with the allens but I did not even have to dent the pipe.</TD></TR></TABLE>
I would like to see any pics you could provide if it's not too much of a hassle. I know it can be a pain to get them taken, edited, hosted, and linked, so I understand if you don't feel like it!
Thad
Old Jan 1, 2008 | 02:11 PM
HiProfile's Avatar
I did a 3" on my 5-bolt flange, which is even tighter. I just made it almost square-shaped, which allowed me to use regular 12mm hex-head bolts. I can fit a normal craftsman socket on them all. Ideally you'd want to use the reducer anyways, as it would help out with flow (less disruptive).
Old Jan 1, 2008 | 05:04 PM
cjordan's Avatar
Default Re: What DP diameter from SC6152 4-bolt flange? (HiProfile)
I called ATP Turbo and ordered a 3 inch V-band from Garrett 4 bolt adapter, and ordered a 3 inch V-band modular downpipe from them. Worked great for me, and wasn't that costly at all.
Old Jan 1, 2008 | 06:35 PM
Ekb18c5_BR's Avatar
any pics????
Old Jan 1, 2008 | 07:22 PM
Schister66's Avatar
Man U FTW
LOL...you would do it that way Matt. If there's anyone good at cutting corners, its you (i mean that in the nicest way possible buddy)
Old Jan 2, 2008 | 03:55 AM
twkdCD595's Avatar
I can shoot a couple pics when I get home from work today and get them posted.
Legion
Feb 22, 2008 05:30 PM
1SlowSi
Feb 5, 2005 02:27 PM
PIC Performance
Mar 18, 2004 03:57 PM
94TurboGSR
Sep 21, 2003 10:51 PM
