Which light weight Flywheel is good for 99 Civic
Old Dec 19, 2007 | 12:04 AM
xelloss's Avatar
Default Which light weight Flywheel is good for 99 Civic
Hi...I need a little help here. I'm planning to purchase CompetitionClutch, stage 2 clutch, and the light weight flywheel as well, but I don't which weight should I go for...
If too light, the rmp will drop so fast, i'm just a daily driver and the ride is just for street use... I know the stock flywheel is around 18lbs, should I just go for 14lbs? or even 11lbs ?? Please give me some advices...thanks guys...
by the way, I'm having a D16Y8 engine...
Old Dec 19, 2007 | 12:26 AM
xelloss's Avatar
Default Re: Which light weight Flywheel is good for 99 Civic (xelloss)
And also....Competition Clutch any good? worth to buy?? Long lasting??
Old Dec 19, 2007 | 10:43 AM
xelloss's Avatar
Anybody Helps??
Old Dec 19, 2007 | 10:48 AM
thisisntjared's Avatar
https://honda-tech.com/zerothread?id=1336368
lsd motorsports makes a good flywheel that i just installed. the driveability is similar to stock, i didnt have to raise my idle or anything like that.
it does take just a little bit of usage to adapt to it, but the 11lb flywheel is totally drivable. the act streetlite and exedy flywheels are also good daily driven applications but i dont have any experience with them.
you could contact mike and see if you can get a good deal on a clutch and flywheel like i did
Old Dec 19, 2007 | 10:57 AM
hades's Avatar
I ran a stock flywheel turned down to ~12 lbs for about 40K miles (auto-x rules kept me from getting an aftermarket flywheel), cheap, drove OK for a DD (needed a little more finesse) and it lasted just fine...
I wouldn't do it if you're going FI or adding tons of power, or running a super HD clutch, but it works fine with bolt-ons and a stg 1 clutch. Make sure it's balanced too.
Don't know anything about your clutch...
Old Dec 19, 2007 | 11:17 AM
xelloss's Avatar
Default Re: Which light weight Flywheel is good for 99 Civic (hades)
thx for the replies guys...
but nobody has any experience on the CompetitionClutch ?
Old Dec 19, 2007 | 11:29 AM
dannis.'s Avatar
I personally love the fidanza flywheel because its a soild design unlike most other companys that cut/drill holes in them to lighting it up. Also my brother is running a comp clutch on his ek and he has no problems with it at all asnd has had it for over 6 months.
Old Dec 20, 2007 | 01:01 AM
xelloss's Avatar
Default Re: Which light weight Flywheel is good for 99 Civic (dannis.)
comp clutch on EK? what kind of flywheel does your brother use? 12 lbs? or even lighter? I fear that if I use a 12 lbs light weight flywheel, the car will be hard to drive, coz the rpm will drop quicker then stock...the OEM flywheel is 18 lbs, I'm thinking just swap a 14 lbs for a DD. by the way... i'm having a Y8 motor and tranny...please give me some ideas which flywheel I should use.....12lbs or 14lbs...~_~
Old Dec 20, 2007 | 04:15 AM
FarinaMotorsports's Avatar
I'm daily driving with an 8lb Fidanza aluminum flywheel and it's perfectly streetable. I actually tried a 14lb chromoly flywheel first and it didn't make as much difference as I hoped so I swapped to the Fidanza. Some people complain about the lighter flywheels, saying it's harder to launch etc, but I love mine and have had NO issues.
Old Dec 20, 2007 | 05:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xelloss &raquo;</TD></TR><TR><TD CLASS="quote">comp clutch on EK? what kind of flywheel does your brother use? 12 lbs? or even lighter? I fear that if I use a 12 lbs light weight flywheel, the car will be hard to drive, coz the rpm will drop quicker then stock...the OEM flywheel is 18 lbs, I'm thinking just swap a 14 lbs for a DD. by the way... i'm having a Y8 motor and tranny...please give me some ideas which flywheel I should use.....12lbs or 14lbs...~_~</TD></TR></TABLE>i guess you didnt read my post:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared &raquo;</TD></TR><TR><TD CLASS="quote">
it does take just a little bit of usage to adapt to it, but the 11lb flywheel is totally drivable. the act streetlite and exedy flywheels are also good daily driven applications but i dont have any experience with them.</TD></TR></TABLE>fears dispelled my only issue now is that the wheels spin a little easier from a stop in the rain, but thats probably because of the clutch.
Old Dec 20, 2007 | 06:25 PM
xelloss's Avatar
Default Re: Which light weight Flywheel is good for 99 Civic (thisisntjared)
thx for all the helpful answers....i think i know which one i should choose now...thx
Old Dec 20, 2007 | 06:29 PM
1.8EG-T's Avatar
Well, my clutchmaster's I have for sale may do you good...barely used and 100 shipped for it...
Old Dec 20, 2007 | 10:21 PM
RiceKillinSI's Avatar
Default Re: Which light weight Flywheel is good for 99 Civic (1.8EG-T)
I like my ACT streetlite flywheel. It is very streetable, but in hind site i probably would have gone with the prolite.
FunForFree33
19
Mar 28, 2021 09:53 PM
gtm_maxwell
Transmission & Drivetrain
Apr 16, 2012 06:36 AM
LS94tegra
May 23, 2008 07:41 PM
funtak
Oct 25, 2007 08:47 PM
integRated109
Oct 2, 2001 03:53 PM
