2000 b16
ok so i just recently swapped my dx with a 2000 si engine!!!
now the car starts but dies after the car has been on for like 20 seconds....
corretc me if am wrong i started up the car with my stock p06 ecu and a p75 i have runs shitty and doesnt stay on
will this stop after i get the p06 converted to run b16...?
also i have a hose from where the red circle is to a black canister that is on the firewall under the fuel filter is that correct...?
get the right ecu for the car. when i swapped my LS i tried running different obd LS ecus, p28s, p06s, ctr, etc ECUs and none of them worked properly. i spent hours looking over the wiring or rubber hosings to see where i went wrong when really it was just the ecu.
You need a P30 (I'm guessing this is a 92-95 DX), or you can convert the P06 to run a P30 map, but you'll probably end up running rich (not perfect). You should get it tuned, but if its stock its kinda a waste
And that "red circle" is kinda vague since you circled your entire intake manifold lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared »</TD></TR><TR><TD CLASS="quote">does it die if you force an idle with the throttle?</TD></TR></TABLE>
yea...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">You need a P30 (I'm guessing this is a 92-95 DX), or you can convert the P06 to run a P30 map, but you'll probably end up running rich (not perfect). You should get it tuned, but if its stock its kinda a waste
And that "red circle" is kinda vague since you circled your entire intake manifold lol</TD></TR></TABLE>
damn!!!! so what would make run normal...?
yea...
Metal_SOL
10
May 15, 2002 08:45 PM
