when installing extended wheel studs
Old Dec 18, 2007 | 08:08 PM
carbon fiber coupe's Avatar
Default when installing extended wheel studs
on a 96 civic....can you just take the old ones out and swap the new ones in or is there more envolved?? any info will help
Old Dec 18, 2007 | 08:24 PM
Luserkid's Avatar
Default Re: when installing extended wheel studs (carbon fiber coupe)
As long as you take off the hub its that simple.
Old Dec 18, 2007 | 08:44 PM
fmrprojects's Avatar
Default Re: when installing extended wheel studs (Luserkid)
the rear is easy. the front requires a bit more work. you need to use a slide hammer to remove the hub
jchandler
Oct 18, 2004 06:50 AM
dj_seloe
Oct 15, 2004 07:45 AM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
ActiveAero
Sep 21, 2002 01:02 AM
Night_Minx
Aug 19, 2002 07:48 AM
